No, delays need more memory than included.Would it be able, to set different delays at the outputs? I use a double bass array and would need 2 delays for the sub arrays.
Yes. I/O -> Dual EQCan the ADI-2 DAC do independent right and light channel EQ?
Awesome, thanks!
Isn't that one of the primary purposes of the USB port on it?Question on RME ADI2 DAC fs: Can the digital inputs be routed back to the PC through USB?
Not all DACs let you record from a digital input.Isn't that one of the primary purposes of the USB port on it?
I just glanced at the manual, it looks like it has built in EQ I can use to set the crossover between my speakers and sub in a 2.1?Most DACs don't. Ours does. And on top of it you even have the choice to record the DSP processed signal. Manual page 22, Loopback to USB.
Yes (at least my ADI2 PRO).Question though, I am a gamer and in Windows I will use Loudness Equalization in some games. My Topping D90 works just fine with this:
Does the adi-2 support Loudness Equalization?
Yes the ADI-2 DAC fs does include loudness equalisation and when set up properly it works very wellI just got a new job with a nice raise so I was thinking of ordering this to reward myself.
As the equalization is being done at the source, it is the equalized signal that arrives at the DAC (any DAC). That is the signal that will be converted from digital to analogue. That would be my thinking on it.I just got a new job with a nice raise so I was thinking of ordering this to reward myself.
How good is the DSP on these vs something like a miniDSP? Does it completely negate the utility of the latter?
The RME ADI-2 DAC FS is strictly a 2-channel DAC, whereas miniDSP usually have 4 or more channels. For example, a 2-in / 4-out miniDSP has a matrix mixer, which let you route signals from either of the 2 inputs (or both) to any of the outputs (see below).How good is the DSP on these vs something like a miniDSP? Does it completely negate the utility of the latter?
That depends on your use case. The miniDSP can be used to integrate a subwoofer (has crossover, delays, etc) and even room EQ, which the ADI-2 DAC does not have, for instance.
That's unfortunate as my use case is indeed 2.1. I'm having trouble putting it together between the preamp/dac/dsp question. For instance, if I went the route of a Topping Pre90 w/ a miniDSP, that leaves me without a competent DAC. Thanks for the replies and I appreciate the diagram. If you can help solve my dilemma let me know, I'm extremely new to this.The RME ADI-2 DAC FS is strictly a 2-channel DAC, whereas miniDSP usually have 4 or more channels. For example, a 2-in / 4-out miniDSP has a matrix mixer, which let you route signals from either of the 2 inputs (or both) to any of the outputs (see below).
The DSP in the RME gives you 5 band parametric EQ, tone control, loudness compensation, and cross-feed.
Also for reference, this is a desktop/PC setup.
