Svperstar
- Joined
- Jul 4, 2018
- Messages
- 350
- Likes
- 227
Something is wrong with your setup, if your headamp overload with only a common 2V/4V input signal.
Try +7dBu at 0dBr volume. -17dBr @+1 dBu is not the way to go as a fixed line out, you're killing SNR & Dynamic Range that way.
So I manually locked in the settings to +7 dBu and 0 Volume and did a volume lock and while this helped a lot but still seemed too loud.
I checked the manual and it says "The levels at the XLR output are 6 db higher"
Ah ha. Dropped it down to +1 dBu and now I actually have some wiggle room on the volume.
