- Joined
- Oct 25, 2019
- Messages
- 11,150
- Likes
- 14,832
Best say what country /region you're in.Any recommendations on where to purchase the ADI-2-DAC FS (v2) ? Best online store? Thanks!
+1 for the ADI-2 Pro version, just get a double 6.3 mm cable (or adapter) and set the internal amp as balanced and you are set.
I turn on and off by resting the 4 fingers on top of the case and pressing the power button with the thumb. This prevents it from sliding around.
B&H is great. Sweetwater is equally good but with a much wider selection of audio gear.Thank you! Purchased from B&H. I know them very well from my photography habit.
I also must say that the menuing and setting system on this thing is the most infuriating of any device in living memory.
Great example, I go through all the settings to dial in an EQ and save to a free preset and it saves and add the designation (lin). I go back to look at the preset and it's all zeros. I go through the whole thing again and save and it works and saves to a normal preset...
No, hold volume button down to change output (or you can set it so it outputs to headamp and rear Jacks at same timeLast confirmation of the day.. you have to physically pull the headphone jack out for line out to powered speakers?
Holding down on the volume button doesn't do anything for me...No, hold volume button down to change output (or you can set it so it outputs to headamp and rear Jacks at same time
Push it in. It switches between outputs.Holding down on the volume button doesn't do anything for me...
It actually didn't... I push it all the way in and it doesn't do anything. I push it in quickly it mutes I push it in and hold it and nothing happens.Push it in. It switches between outputs.
You may not have the Line Out enabled then in the settings, but that is definitely how you switch between the outputs.It actually didn't... I push it all the way in and it doesn't do anything. I push it in quickly it mutes I push it in and hold it and nothing happens.
Thanks I'll keep playing with it but when I pull out the headphone jack it turns on the line out immediatelyYou may not have the Line Out enabled then in the settings, but that is definitely how you switch between the outputs.
That's not by default. See SETUP - Options - Phones/DSD - Mute Line (page 27 of the manual):Push it in. It switches between outputs.
OFF, vs. Phones, Toggle Ph/Line. Toggle Plugged. The default, vs. Phones, activates mute of
Line Outs when inserting a phones or IEM plug. Alternatively Toggle activates the ability to man-
ually switch between 'front' and 'rear'. It allows to have the Phones/IEM connected all the time.
To change push the VOLUME knob for half a second. [...] Toggle Plugged
additionally activates the switching between Phones and IEM, automatically detected by the
sensor contacts of the two outputs.
This. Thank you.That's not by default. See SETUP - Options - Phones/DSD - Mute Line (page 27 of the manual):
