RSL CG25 Center Speaker Review
Rate this speaker:
    Votes: 26 16.6%
    Votes: 70 44.6%
    Votes: 50 31.8%
    Votes: 11 7.0%
Robbo99999
Still don't reckon much to these centre speakers!
Joe Smith
Is this RSL the "new" reboot of Rogersound Labs? I know they are building their own product again...my very first speakers were Rogersound Labs bookshelves from the Van Nuys, CA store in 1974. They were pretty great.
TimW
Seattle, WA
I didn't think I'd ever see a recommendation of a MTM center from Amir. This one seems especially flawed which is even more confusing. For the same price, here is one that doesn't need EQ to sound good, has no resonance, and has lower distortion with higher overall sensitivity.
Keened
The only four I've seen which look to be alright are the C208 and C52, KEF center and Ascend Acoustics center all reviewed here. And you can see why. They are something of a tall center with vertically oriented tweeter and midrange flanked by woofers. A TM/WW layout?
I usually see them written out as WTMW with the understanding that the TM is vertically aligned.
And you're right, it is for sure a compromised design from the start, but it has surprisingly good psycho-acoustical properties once EQ'd. Also it costs 1/4 of what that particular AA center costs and fits in better with most home decor :)
They leverage a lot of the benefits the transmission line to create what is widely considered to be 'good sound' from most subjective reviews; I suspect the phase coherency and even harmonics play a larger role in determining what 'sounds good' than the metrics used for what 'sounds right'.
But yeah, if you want an ideal radiation pattern center, you can't beat a vertical alignment. It's just a hard sell to work into the layout for most people.
Keened
Oh that is very interesting, released late last year. I've been hearing about the new Sierra line up but not much about their Signature line. Definitely worth looking into.
Edit: oh but it's rear ported, got to give it some room off the wall
TimW
Seattle, WA
I actually own the CMT-340SE2s and for stereo they are very good. If I were to set up a surround sound system I would be hesitant to get the matching center due to the MTM configuration but if Amir says it can be wide enough dispersion for a love seat then maybe it's fine.
rvsixer
Somewhere at the base of the Rockies....
Agree on all points in this post, unfortunately the 340SE2 still has the same and expected toppled 2-way MTM issue - most all seem to hover around +/- 15-20 degrees horizontal dispersion (+/- 6dB window):
https://cdn.shopify.com/s/files/1/0...0SE2_Contour_Plot_-_Vertical.png?v=1667559632
Note this plot is from the mains 340SE2 page...so it would be the horizontal dispersion for the 340SE2 center. In fairness, and imo welcomed move, Ascend has developed a new "Off-Axis Estimated In-Room Response" measurement in conjunction with Klippel that somewhat eases toppled MTM concerns.
Sadly no Signature series monitor improvements (which would then work great for surrounds/Atmos) in the lineup (or forthcoming per their forums), which at this point is keeping me from going with a full Ascend setup. I have a competitor small compact toppled MTM in for ASR test, that is promised to break the 20-degree barrier...I need +/- 25 degrees for my new small HT build.
TimW
Seattle, WA
Sadly no Signature series monitor improvements (which would then work great for surrounds/Atmos) in the lineup (or forthcoming per their forums), which at this point is keeping me from going with a full Ascend setup. I have a competitor small compact toppled MTM in for test, that is promised to break the 20-degree barrier...I need +/- 25 degrees for my new small HT build.
On the forum Dave has said he doesn't want to mess with the CBM-170SE design due to its popularity. However he has mentioned possibly creating an alternative model optimized with the Klippel. I wouldn't count on one coming out anytime soon though.
sarumbear
Unless I am reading it wrong, the EQ being discussed to apply, is to tame the bass response. The narrowing of the horizontal dispersion occurs well above that range, so the -6dB response dip at +/- 18 degrees still applies, EQ or not?
Once you tame the bass the dip drops to 4dB
rvsixer
I caught the first reason (but why mess with the 340SE then I wonder). Missed the second post from him. But yea either are a ways off, unless they are already in hush hush progress :rolleyes: ....
sarumbear
Where can I see the dispersion diagram?
sarumbear
sarumbear
That’s vertical, which is not as important in a centre speaker use case. May I ask for the horizontal? Or the source of the measurements?
