i had feeling but wasn't too sure . not sure how many are used in the movie i think typical disco would have x4 each corners of the disco dance floor . often some are suspending by chains from ceiling angled downwards at the dance floor . good to have someone that can spot the speaker . thanksYes, the top metal horn could be a AL. If the wood cabinet is a Voice of the Theatre remains to be seen.
Well unless Altec paid for brand advertising in the movie... they would have removed branding.then have match . odd can't see the altec lansing label on side of the speaker in the movie ?
Learning how to quote.sure how many are used in the movie i think typical disco would have x4 each corners of the disco dance floor . often some are suspending by chains from ceiling angled downwards
If you're testing how to quote, best done in here rather than a live thread;Learning how to quote.
Sorry, didn't know the threads in the "testing area" were considered "live." I just stuck this practice reply at the end of a random thread there. Should I start a new thread to practice? How can I practice a quote that way. Sorry, I'm new to this. I couldn't find specific instructions on how the quotes work, so I was gonna mess around a bit. I think no matter where I put a practice post, it will show up in the "new posts" and "latest activity" list, if that's an issue.If you're testing how to quote, best done in here rather than a live thread;
Testing Area
If you are trying to learn the forum software and or experimenting, you can post here.www.audiosciencereview.com
JSmith
No I'm sorry... I didn't realise your post was actually in the test area, as the thread title misled me, plus was looking at other threads. So you're in the correct area, my sincere apologies.Sorry, didn't know the threads in the "testing area" were considered "live." I just stuck this practice reply at the end of a random thread there. Should I start a new thread to practice?
Just highlight what you want to quote and select reply;I couldn't find specific instructions on how the quotes work
Yes, I'd guess it's a 511B horn.Yes, the top metal horn could be a AL. If the wood cabinet is a Voice of the Theatre remains to be seen.
They might get sued too, unless they talked to Altec first.makes sense no product placement
