Barrelhouse Solly
- Joined
- Aug 13, 2020
- Messages
- 378
- Likes
- 362
I agree with all 10 points. I don't think they're radical takes on audio.
I've played music and sung all my life at the amateur and semi-pro level. I've heard a lot of live music. I've heard live music without amplification from a lot of different listening positions. I have no doubt that it's almost impossible to reproduce live music perfectly faithfully. I know that unamplified live music sounds different depending on where you sit, the space you're in, the instruments used, and the players involved. Amplification adds another dimension. Microphones don't respond in the same way that the human ear/brain does. Part of it is the physical limitations of even the best microphones, part of it is physics, and part of it is what the human nervous system does.
If you listen to different recordings of the same classical piece you'll undoubtedly hear differences in the sound that are the result of recording aside from differences in interpretation. Bass is probably the easiest thing to notice. Sure, part of it is interpretation, but part of it is how the producer wanted the recording to sound.
As far as I'm concerned, if you have a sound quality in mind, EQ to your heart's content. Measurements are a great decision support tool for audio. I want equipment that produces the smallest measurable deviation from the source that I can afford. I also want equipment that I can use to fool with the output.
