- Joined
- Oct 25, 2019
- Messages
- 11,133
- Likes
- 14,806
Diffuse field EQ does not exist. What Robbo means is he removed the Harman Bass boost and slightly adjusted the treble a bit.
Diffuse field is a measurement method for calibrating HATS. The HATS is placed in an anechoic room with speakers all around it and the signal from the HATS is then measured resulting in the FR curve that looks the most like Harman minus the bass boost (which is derived by preference of a fixed frequency bass slider people could adjust to preference). That way an echoic room is 'emulated' somewhat and as this setup is described multiple HATS manufacturers can calibrate to that standard.
In the 'old' days and still today. People using HATS use the diffuse field method for headphones (for which it really isn't suited but you have to do something). At least it is better than using the other known correction method for measuring speakers.
So when a headphone manufacturer has developed a headphone using a calibrated HATS using diffuse field compensation and didn't even listen to it but relied on the measurements and 'f'-ed around with ports, pads and damping to get the bloody driver they had to measure well on their HATS with their incorrectly used diffuse field correction (by lack of something better) they say 'it is diffuse field tuned' but no EQ has been used. Only the 'wrong' correction has been chosen.
Not for your benefit of course, but other readers, a useful primer on Harman etc . About as deep as I care to go. Because whilst this is a science-ish/ measurement led site, some of us are not avid scientists or measurerbators . https://www.headphonesty.com/2020/04/harman-target-curves-part-1/
