solderdude
Age could make them sound a tiny bit 'darker' due to the foam degrading and the drivers being closer to the ear.
Its the same reason why Amir's measurements of the HD600 are very similar to his HD650 measurements as the HD600 with older and worn pads sounds closer to a HD650 with newer pads. More 'warmth' with thinner pads.
Old (black screen HD650) and the exact same HD650 but with new pads.
On top of that the new pads you can buy now, again, have changed a little yet again and are a hair 'brighter'
So buy some new (original Sennheiser, not alternatives) and put them on there. No need to buy the new version.
You can also replace the headband foam at the same time, this too tends to soften too much after that many years.
