Serious Question: How can DAC's have a SOUND SIGNATURE if they measure as transparent? Are that many confused?
Goodman
Of course they don't measure the same. Different opamps are optimized for different things. No need for Amir (or me, for that matter) to repeat the measurements that are on every opamp's datasheet.
Ok then; If a manufacturer states that he would have used a different op amp if cost contraint had allowed; is it worth switching? Exemple Asus Dac
TheBatsEar
Germany
If the op amps measure the same (and given all other things like failure rate and so on are the same as well), i would expect the manufacturer to pick the less pricey part to make the product better value.
If that was your question. :cool:
SIY
Alfred, NY
Not unless you're knowledgeable enough to rework the circuit to suit another part. These are not interchangeable jellybeans.
And that's making a BIG assumption that this isn't marketing ("If you want the good stuff, you have to buy our more expensive product.").
TheBatsEar
Germany
They are if they measure the same and the other factors are the same as well. Why is that hard to understand?
True, this one i can't deny. :)
SIY
Alfred, NY
No two different types of opamps "measure the same." That's why they're different types.
Killingbeans
Bjerringbro, Denmark.
Are you saying all op amps are equal and dont sound different? The op amps in a £19 Chinese media player are equal to the op amps in a high grade Dac? Just asking?
If they are both reasonably good op-amps and are implemented sufficiently well, yes.
Op-amps themselves are not a bottleneck when designing with audible tranparency in mind.
ferdybossy
To hear the difference. You don't need knowledge, you can't learn this. Like everyone who graduated cum laude from conservatory. Not all become world famous. Good ears are needed to hear the difference. For example, you hear differences between the inversions of the same chord.
Not every audiophile is a snob. And the claim that every DAC sounds identical. Corresponds?!! with, the handling of a Porsche Cayenne is the same as the Dacia Logan.
Real blind testing is unnecessary. You hear the differences. I can still remember very well, went to listen, was curious how good such an installation sounds, which I absolutely couldn't afford.
5 digits before the decimal point. He put on a record. First thing I said, you got some wires connected wrong. He went to look and told me, you are the first to hear this. Real, amounts don't interest me.
TheBatsEar
Germany
When has this forum started to decay?
I remember maybe 4 weeks ago we had one subjectivist every few days. Now we have several in every thread, every day new ones too.
Killingbeans
Depends on how complicated a job you believe the car has to do. To you it might be an actual race, but to me a human being listening to music is more like going 100m in a straight line in less than 5 minutes. The Dacia will do that just fine.
No doubt about that. But an experience is not the same as establishing cause and effect.
TheBatsEar
Germany
What am i reading?
voodooless
Netherlands
You know that musicians don’t do better than “normal” people in listening tests, don’t you?
Why not give it a try? What do you have to lose?
ferdybossy
Tastes differ, I can still remember when I first heard Bach. Was certainly not overly enthusiastic, music can be compared to math. You start with 1+1 and if you know enough math you can calculate where the moon is, if you want to land a rocket on it. Not all genres require better sound reproduction.
Doodski
You can say that again! Some of the pop and rock music that I listen to sounds horrible if one really admits the truth and I don't mean the musicians. :D
Pdxwayne
This is not against you specifically. But I have read a few people repeat your statement.
Are there scientific researches that absolutely support the claim that "musicians don’t do better than “normal” people in listening tests"? If so, please share? Thanks!
