Share your in-room measurements?
Eetu
Helsinki
Depends on the dimensions/layout of your room. Start with an equilateral triangle setup (distance between loudspeakers is the same as the distance from loudspeaker to listening position).
If you want to share your in-room measurements you first need a measurement mic. Here's a great tutorial to get you started:
lay these speakers on the back facing the ceiling and see what happens.
I don't think that's a good idea..
Use the search function and read more about speaker placement, room modes, digital room correction etc. Feel free to share any in-room measurements when you are ready!
IPunchCholla
First measurement. LP1 about 4 feet from speakers.
Got some work ahead dealing with base modes.
TurtlePaul
New York
I bet the front of your speakers are 15” from the wall?
The 225 hz thing is almost certainly SBIR and not a bass mode.
Bass modes tend to be peaks and <100 hz unless you have a very low ceiling.
IPunchCholla
Thanks! They are. Difficult to position them elsewhere in that room. Im assuming I should start with treatment behind the speakers and bass traps in the corner?
YSC
Thanks! They are. Difficult to position them elsewhere in that room. Im assuming I should start with treatment behind the speakers and bass traps in the corner.
Maybe try some furnitures to diffuse the sound in rear wall? that distance the bookshelves etc. likely works. seems like the extreme highs are a bit shelved up also, worth EQing a bit?
TurtlePaul
New York
I have been playing around with my filters more. Four filters, with the highest at 325 hz:
74 hz, - 7 dB, Q=6 - This is my highest bass node, I could maybe address the one in the 40s, but the lowest is at 25 hz where my sub is rolling off anyways.
140 hz, +6 dB, Q=1.1 - This is to address what I believe is my coffee table and TV console bounce which is less than a foot below the speaker level.
250 hz, +5 dB, Q=6 - This I believe is addressing SBIR off my back wall.
325 hz, -5.5 dB, Q=3 - I don't know why, but I have some extra power at this level. I may back this one off by 1-2 dB.
I have just been adjusting the room with good effect, but I am tempted to try +2-3 dB centered at 1.65 kHz, Q approx. 3 to see that they sounds like.
IPunchCholla
Been having fun using REW to produce different EQ filters: 0 Slope 1db flatness from 20-20k, 1.0 slope, 2.0 slope, those variations for just the lower frequencies, those variations for slightly relaxed fit. Based on all of that, it looks like in my room at least, trying to equalize upper frequencies creates a number of humps (room modes?) in the midtowns and up. Below is without and with a 1DB fit from 20-20000Hz with no room curve (just a fitted flat dB target).
So I decided on a 2dB fit from 2 to 3000HZ at a room slope of 2.0 and added a low and high shelf. I was going to measure again, but my wife is going to bed so that will have to wait.
bjmsam
Mount Airy, MD
After reading the Comb Filter Effects thread and reviewing the Impulse Responses page in the REW documentation and being inspired by the string method, this morning I measured L and R separately from the MLP, plotted the results in the Impulse window, and used CTRL - Right Mouse Button to estimate the primary reflection distance to confirm that the ceiling indeed is at fault. I'm finding few options for drop ceiling diffusion so most likely will end up adding more absorption to a room that already is pretty dead...
Treating the ceiling eliminated the reflection as anticipated.
Before:
After:
Clarity and imaging have improved but comb filtering remains audible and annoying. IDK where to go from here, so suggestions would be most appreciated.
ernestcarl
bjmsam
Mount Airy, MD
The cause may be the very early reflections under 0.5ms — could it be the chair or from another nearby surface?
REW estimates ~5" for those very early reflections that appear in both the left and right graphs (-20dB is enough to be so disruptive?). Removing the speaker grille resulted in no measurable difference, so I will try removing the chair (which is fabric, but perhaps more reflective than assumed?) and measuring from additional locations in hopes of tracking this down. Thank you!
warthor
Hi All,
Here are some of my first measurements. I definitely need some help. I recently purchased the umik and MiniDSP 2x4HD to work on the subwoofer response (which I am pretty happy with overall for only having a single subwoofer). I would like the curve to be much more flat and wonder why the subwoofer response is so elevated. This is after running and correcting the subwoofer response and moving the subwoofer around in YPAO to align the sub and main. Any help is appreciated!
KEF R7, Klipsch R-115SW, Yamaha A3070
YSC
Hi All,
did you do EQ already? that looks pretty normal sub behavior with room boundary gain and generally the overall FR looks pretty good
ernestcarl
Hi All,
Don't know about YPAO, but it would be helpful if you could post an image overlay of the sub only and main(s) speaker response traces with and/or without EQ.
Erici
Hi All,
A simple action to try: Reduce the gain on your sub by about 4 dB and see how it sounds.
Steve Dallas
A Whole Other Country
If your speakers are near the side walls (within 3 feet), corner bass traps can help. You should also benefit from treating the front wall, although you need a minimum of 4" thick absorption behind the speakers to reach decent effectiveness down to 125Hz. The treated area needs to be at least 4 x 4 feet to have much effect.
Here is a little chart I made showing the NRC of common thicknesses of Owens Corning 703 (uncovered) at various frequencies:
You start to realize usable bass absorption at 4". Six inches is much better if you have room for it.
Here is a table showing the SBIR frequency at different front baffle differences from the front wall. This does not account for the additional cancellation effect of floor, ceiling, or side wall bounce. (This is how TurtlePaul knew your speakers are 15" from the front wall). The formula is 340 / (4 * distance (m)).
Distance (in)Distance (m)SBIR Frequency (Hz)
120.3048279
130.3302257
140.3556239
150.381223
160.4064209
170.4318197
180.4572186
190.4826176
200.508167
210.5334159
220.5588152
230.5842145
240.6096139
250.635134
260.6604129
270.6858124
280.7112120
290.7366115
300.762112
310.7874108
320.8128105
330.8382101
340.863698
350.88996
360.914493
380.965288
401.01684
421.066880
441.117676
461.168473
481.219270
501.2767
521.320864
541.371662
561.422460
581.473258
601.52456
621.574854
641.625652
661.676451
681.727249
701.77848
721.828846
741.879645
761.930444
781.981243
802.03242
822.082841
842.133640
862.184439
882.235238
902.28637
922.336836
942.387636
962.438435
982.489234
1002.5433
1022.590833
1042.641632
1062.692432
1082.743231
1102.79430
1122.844830
1142.895629
1162.946429
1182.997228
As you can see, you have to move your speakers waaaaaaaaaaaaay out from the front wall to remove any audible SBIR concern from its influence. No one I know has a listening room that large.
IPunchCholla
I’ve been building sound absorption. Right now I have 4” thick sheets (15”x48”) in the front and rear corners. That made a difference bass is much smoother sub up to the SBIR induced drop. And that is easier to fill. I’m planning on putting 4” thick behind each the speakers too, and maybe on the front wall between them. I think my reflections will also improve with smaller panels in the upper corners, but I’ll finish the corner ones (built the frames this weekend for the corners, I hope to cover next weekend). Build the behind speaker ones, then measure and see where I’m at.
sharock
Below is the in-room measurement of the D&D 8c from Erin's review, measured in his living room, plotted with the Klippel predicted in-room response. I'm curious, would this be considered a "good" in-room response? Clearly the bass <50Hz needs bringing down, but even with the cardioid performance there is a lot of unevenness below 1KHz. How audible would this jaggedness be? Can room EQ fix the in-room response considering all the dips? I imagine there are many people here with typical, untreated living rooms. Is this the best we can hope for even with a SOTA speaker like the 8c?
YSC
I would say it looks darn good. The few deviations are obvious various room modes where simple eq can deal with easily
abdo123
Brussels, Belgium
Yes that’s pretty much what to expect. You can use EQ to bring some high Q resonances like at 120Hz and shelf the bass a bit below 50Hz and that’s it.
sharock
The dips just below 200Hz and at 250Hz are 7dB below the PIR. Are these easily dealt with by EQ? I keep reading on here not to EQ up dips.
