nightlite
- Joined
- Nov 29, 2022
- Messages
- 6
- Likes
- 8
Hey guys,
I have a SMSL SP200/M200 Stack. I noticed, when the DAC volume is set to 0dB, the Music is clipping with some high volume sounds. If I lower the volume to around -10dB on the DAC everything is fine. It happens both over XLR and RCA. I also tried a IFI Zen Can AMP with the DAC over RCA and get the same behavior, so im pretty sure its the DACs fault.
I also have a Fiio BTA30 Pro (Bluetooth) DAC as well as an Audient Interface. Both of them can send 100% volume into the SP200 AMP without the music clipping. The source is the same, Spotify at 100% volume. I use the optical input of the M200 DAC but i have also tried the USB/Coaxial input, they all show the same behavior.
First i thought that the problem might be, that the M200 DAC sends too high voltage, which the AMPs cant handle. Or maybe that the DAC applies some digital gain to boost the signal, which would cause it to clip. But both my Audient Interface as well as the Fiio DAC with 100% volume are actually louder than M200 without clipping. If i volume match the M200 with the other 2 DACs, the M200 clips badly.
Does anybody know what might be the reason for that? Is the DAC broken? Its not a huge deal, because i can simply lower the volume on the DAC, but i think the DAC should at least be able to send out the same volume as the Fiio BTA 30 or my Interface, without the Audio clipping.
