SMSL M500 DAC and HP Amp Review
scherbakov_al
Санкт-петербург
Dexter_prog
I grounded the M500 by grounding the raspberry pi attached to it via USB (connected the 5V ground to earth). But if you connect it to a grounded amp it should be theoretically already grounded.
it is connected to a grounded amp (via RCA, also tried adding an optical cable as well)
bogi
Slovakia
There is no preamp section- no extra circuits that can be bypassed- switching the D90 to DAC mode isnt taking anything out of the signal chain- just disabling the ability to reduce the volume- I'll confess to not understanding where in the signal path that happens though :rolleyes:
Here is where @JohnYang1997 tells me I am totally wrong- but I think Im just remembering a previous post of his.
EDIT- here - he is talking about e30 but pretty sure applies to d90 too https://www.audiosciencereview.com/forum/index.php?threads/topping-e30-dac-review.12119/post-481519
In both cases (ES9038PRO and AK4493) it happens within the DAC chip in the DSP part of PCM section. The ESS block diagram shows volume control as part of the Oversampling filter module.
The AKM block diagram shows it to be part of of the DATT module, before the Oversampling module, which is here called as De-emphasis & Interpolator.
Jimbob54
Somewhere between the warp coils and the hyperdrive then. Roger that ;-)
Jose Hidalgo
France
This integrated DAC & amp looked really nice... until I saw its 50mV output. 81dB seems really poor when devices such as the "little" L30 have 94dB which is nearly 16bit of dynamic range. This is really surprising, as the M500 DAC part looks way better. Could it be that the amp part was poorly designed ? (sorry if it was said before, 75 pages is a bit too much)
Veri
The amp is a freebie. It can go pretty loud for an embedded amp actually, pretty close to DX3 performance. Best results will be had with external amp, but overall it isn't bad at all. As you say with most sensitive headphones, 50mW will be quite a bit better on L30.
Pretty fierce competition though with Sabaj D5 and DX7 Pro... (both have balanced headphone amp)
Jose Hidalgo
France
Understood. Better consider this as just a DAC, the amp part being a bonus. In that case, for its price it's a great DAC. :D
Budget-wise, Topping stack remains the best bang for the buck I guess.
Jimbob54
I've never really used the HP amp in my m500. The odd times I have, it just doesn't sound "right" like my other amps. But I haven't gone to the bother of blind testing
icsi85
So you use M500 as a DAC. With what Headphone amps?
Jimbob54
Currently a Geshelli Erish but other amps too including THX 789. All work as they should. Nice and clean and powerful.
Toku
Japan
I'm not using ASIO, I'm running WASAPI mode in Roon
You can play PCM files with the Windows audio engine without installing a driver, but that method does not bring out the full potential of the M500.
