SMSL SH-9 THX 888 Balanced Headphone Amp
NightlyNurse
Sorry if this has been discussed already and I didn't see it. Is this the first "True balanced" THX headphone amp. I've been waiting for one. On the thx 789 the 3d space and pinpoint imaging is warped when going to balanced. It's flawless on single ended. I believe it's from the conversion from balanced to single ended back to balanced since my other true balanced amp doesn't have this problem. Thanks for any help you can provide
Veri
Your 789 might be defective.. mine sounded identical on both outputs except balanced being much louder of course. But to answer your question, no, the SH-9 seems to be a near clone of the SP200, same specs inputs and outputs. Not "true balanced".
If a true dual mono amp is what you're looking for, the Topping A90 offers just that (4 amp chips, 2 PSUs...) at THX AAA levels of performance.
N
NightlyNurse
Hi. Thanks so much for the reply. I considered the A90. Especially now that it's on sale. My concern was that it could be too much power as I run my headphones balanced. I use a Sennheiser Hd660s and have a Meze Empyrean on the way. I'm barely passed 9 on the volume dial when listening. Would the A90 have too much power for my case? Thanks again for all the help. Much appreciated
Veri
Hey no worries. I have a lot of experience with A90 so I can tell you, just use low gain and everything will work. There's no real penalty to low gain either, on L30 best performance is on unity gain but not so on A90. There's no reason it would have too much power ;)
If you are also using a balanced DAC and output is too loud, too fast, you can always lower the volume some dBs on the DAC side to have smoother volume control on amplifier side.
N
NightlyNurse
Awesome. I'll give it a shot and order one while it's on sale. Thanks again for all the help. Really appreciate it :)
N
NightlyNurse
Sorry to bother again. I ordered the A90. My DAC is the Gustard A18MQA. It has a hotter signal compared to most dacs at 6V XLR. Would this work ok for the Topping A90? It won't damage it?
Veri
Won't damage it, but man that is a hot output. 50% more than standard in consumer devices. If you're on Windows, if you right click the volume you can put it in dB here, it might make sense to lower it a little like so to allow for more usable volume knob range. On OSX you can do it in MIDI settings.
N
NightlyNurse
Awesome. Glad to hear it's safe to use. I absolutely love the sound out of it. It's my favorite dac. Also I had no idea you could do that in windows. That's great to know. Thanks so much for the replies. It really helps. I won't bug you no more haha. Be safe out there :)
wrigglycheese
This is 'effectively' the same as pre amp in EQ APO ?
Pritaudio
It has a remote, which is rare. A big thing indeed.
volume uses relays too.
