confucius_zero
- Joined
- Nov 22, 2018
- Messages
- 541
- Likes
- 346
The DAC 5 takes what I’ve previously heard as slightly-flattened notes and lofts the piano flourishes so they float over/amongst the guitar and percussion that open the track like motes of dust twinkling in shafts of light through a dusty room. It does this with such exquisite tonal definition that I get mentally caught on it and I space for the next 20 seconds-or-so of the song before I’ve recovered. The slightly-gated mic effect on Pond’s voice as he comes into the mix creates a lush, trailing-edge space without any sibilance around his vocals in the upper registers and the commingling of Pond and Stevenson’s voices as she joins with him on harmonies around 1:10 into the song blend seamlessly tonally while remaining equidistant from one another in 3D-space. Timbre and tone to wood-bodied instruments or the slide guitar backing up Pond’s picking are a class apart and show the 5’s musical-translation pedigree, putting it up there with the very best I’ve had the good fortune to hear (totaldac d1-direct, dCS Rossini, LampizatOr Pacific). Bass guitar and drumming on the track are of particular note with tangible, organic tonal texture and color to both in the form of string separation and realistic alloy snap to the metronomic staccato of the high hat.
It uses a carefully-selected-by-hand NOS (new old stock) Analogue Devices AD1865 18-Bit (Multi-bit) stereo DAC chip that has a conversion ceiling of 18/96, is no longer in production, has zero over-sampling, no jitter reduction and no re-clocking, noise shaping or filtering of any kind.
...it operates in Pure Class A with a Zero negative feedback, Single-Ended circuit topology and valve rectification. Legendary Black Gate and Cerafine Audio capacitors, along with Tantalum film resistors help conduct internal circuit paths with wiring consisting of Audio Note 99.99 per cent pure silver cabling.
This thing has just about everything on the esoteric checklist. What more could an audiophile ask for!
I strongly suspect that's the best measuring device with audio notes name on it.They should send it in for measurement. Obviously the numbers will justify the price.
Audio Note collaborated with EVGA to produce this sound card Amir measured: https://www.audiosciencereview.com/...d-measurements-of-evga-nu-audio-pc-card.9137/
You already won. The performance should be on par with the TotalDac. Oh wait, sorry! This one sounds even warmer...What a crock of shit. It wouldn't even measure as well as a Topping D50s. I'd bet money on that.
43K$ for a thing limited to PCM 24/96 and no USB input. I'm afraid you where right.I always perceived Audio Note products as scam, but I'm ready to be proven wrong.
They should send it in for measurement. Obviously the numbers will justify the price./QUOTE]
If (when) it doesn't, well, obviously the right things are not being measured
Looking inside the DAC 5 one finds an ingredients list which many manufacturers would A) envy and trade their eye teeth for, B) emulate to some degree.
