- Joined
- Oct 3, 2019
- Messages
- 288
- Likes
- 518
I am selling my licence to FabFilter's excellent Pro-Q 3 parametric equaliser plugin.
FabFilter have confirmed to me via email that this is possible. Following purchase, I will complete FabFilter's online transfer form to send you the licence.
Price is £110 (UK RRP is £144).
Please let me know of any questions.
Here is the product page: https://www.fabfilter.com/products/pro-q-3-equalizer-plug-in
Key features:
Key features:
- Available in VST, VST3, Audio Units, AAX Native and AudioSuite formats (all both 64-bit and 32-bit)
- Up to 24 EQ bands
- Supports stereo, mono and surround channel layouts (up to Dolby Atmos 7.1.2)
- Optional Dynamic EQ mode for all bands (Bell and Shelf shapes), using any slope setting and with perfect analog matching, with optional external side chain triggering
- Gorgeous Retina interface with large interactive EQ display, multi-band selection and editing for maximum ease of use and efficiency
- Ultra-steep 'Brickwall' slope setting for LP and HP filters
- Full surround support (up to Dolby Atmos 7.1.2) with intelligent speaker selection
- External spectrum visualization from any other Pro-Q 3 instance, including collision detection
- Per-band mid/side or left/right processing, so you can EQ the mid, side, left or right signals separately
- Operates in zero latency mode, linear phase mode with adjustable latency or the unique Natural Phase mode
- Flat Tilt filter shape, a flat tilting correction curve over the whole audible frequency spectrum
- Spectrum Grab: just grab and adjust a peak in the real-time spectrum analyzer right away!
- Different interface sizes and additional Full Screen mode
- Filter shapes: Bell, Notch, High/Low Shelf, High/Low Cut, Band Pass, Tilt Shelf, Flat Tilt
- Universal filter slope support for all filter types, up to 96 dB/oct
- EQ Match feature to automatically match the spectrum of another Pro-Q 3 instance or an external signal
- Built-in spectrum analyzer with Pre-EQ, Post-EQ and external spectrum visualization, adjustable range, speed, resolution, tilt, freeze and collision detection
- Auto Gain and Gain Scale
- Optional piano roll display to quantize EQ frequencies to musical notes
- Different display ranges: 3 dB and 6 dB ranges for mastering, 12 dB and 30 dB for mixing
- Intelligent solo mode makes it easy to find problem frequencies and hear the effect of a band
- Phase Invert option to change polarity
- Large output level meter with peak level readout
- Extreme CPU optimization: Pro-Q 3 uses very little CPU and memory, so you can use hundreds of instances in a session
- GPU-powered graphics acceleration
- Double-click text entry of parameter values
- Supports common Pro Tools hardware control surfaces
- MIDI Learn with option to control the currently active band
- Undo/redo and A/B comparison
- Smart Parameter Interpolation
- Sample-accurate automation of all parameters
- Extensive help file with interactive help hints
