Solid Core Wiring
Familiarity with solid core wiring:
Status
Not open for further replies.
antcollinet
UK/Cheshire
I know how to do it properly, or at least I think I do. But only with one person… my wife.
If you think you do - then you probably don't. Note it is ABX - not A, then B then "can you hear". If you cant double blind it, then you need to set up so your subject can't pick up any cues from you. They should not be able to see or hear you. And obviously the ONLY thing that should be changing is the cables you are comparing.
A
arpinnurmela
Sacramento
No. I did the X part just to make sure. But obviously my sample size of one is problematic.
radix
Interesting... Of course I know about it being used inside of walls, but I was curious about people who have used it for interconnects. I haven't tried AntiCables, but I have been making my own DIY solid core wires air-gapped inside of teflon. And I've done "blind-ish" trials with this stuff with non-audiophiles and audiophiles who've all said they heard a difference. One of the best trials I've done is to put solid core copper wiring on one speaker and use stranded wire on the other, and every time, no matter the person, they hear a difference. I wasn't sure if what I was hearing was accurate, which is why I started doing careful comparisons and bringing in other people to listen.
I'm wondering if the tests have been done with coated solid core wiring (a la AntiCables) or my style. I haven't personally tested AntiCables, so I can only talk about the wires that I've made for myself and others.
If you ever re-do the tests, I think it is important to establish that someone cannot distinguish the two speakers used in the test before changing the wiring in one. And, of course, you'd want to play the same channel through both and voltage balance both.
It would also be interesting to disassemble a speaker, not change the wiring, re-assemble the speaker and do the tests. This would answer the question about if the change is due to the disassembly/re-assembly and not the wiring. For example, there might be a change in the interior foam or a speaker got rotated or a phase is backwards.
One wants to control for other possible and likely causes of a perceived sound difference. It could very well be that your test subjects all heard a difference, but was that due to wiring or some other cause?
Marc
antcollinet
UK/Cheshire
The x is not "jsut to make sure" it is fundamental part of the test. How many repeats? How were results recorded? Sample size of one is fine.
antcollinet
UK/Cheshire
Don't try to invent how to do the test (it sounds like you are making it up as you go. Read up how to do it properly.
A
arpinnurmela
Sacramento
Marc
I have another set of speakers I’m about to do this internal rewire for. I’ll post the results here.
antcollinet
UK/Cheshire
Like I say - you need to read up on it.
A
arpinnurmela
Sacramento
Marc
The phase issue was something I’m super paranoid about in these rewires. So I tend to check that one about 5 times or more.
VintageFlanker
Paris
Even more to the point, I also couldn't believe what I was hearing.
Me neither. I could not believe what you were hearing.
I know how to do it properly, or at least I think I do. But only did so with one person… my wife.
Claiming to pass an ABx blind test of cables is an even more extraordinary claim than just saying you may hear differences under regular conditions.
I don't believe you did one nor the other anyway.;)
A
arpinnurmela
Sacramento
The me neither part was funny. Props for the wit. I was waiting for someone to roll that way.
A
arpinnurmela
Sacramento
Yes please. I would like to see your physics model and calculations.
Yeah. Sure. I’ll dig up my grad school work and post it for you as soon as I find the box I put it in. Maybe you can do the calculations instead. Might be faster.
Status
