SONCOZ SGD1 Audio DAC Review
This is a review and detailed measurements of the Soncoz SGD1 Audio DAC. It was kindly sent to me by its designer. You can be forgiven for not knowing this brand. It is a new company formed by our member @Ben1987 who had previously designed the super popular Khadas Tone Board DAC! He has left and designed this much higher tier DAC. The SGD1 costs US $469.99 plus shipping from Amazon.
The design is unique for a desktop DAC:
The volume control is a rotary encoder. The ring around it indicates volume level. I sort of expected a numerical display to the left of it. You can easily set the input and filter types by how long you push the encoder in, and then rotating it.
Lots of inputs and outputs are available:
Nice to see Coax output and USB-C jack.
I don't see an external antenna but there is Bluetooth and one of the videos indicates Wifi capability!
DAC Audio Measurements
As usual we start with our dashboard measurements:
Wow. That is some distortion and noise performance! Highest level distortion product is under -130 dB meaning it is absolutely, positively inaudible. Noise must be low enough to push SINAD up to near 120 dB, placing the SGD1 almost at the top of the charts:
From here on, we have to keep our fingers crossed that the rest of the measurements follow the same way. First up is signal to noise ratio which we can already predict to be excellent:
And excellent it is.
Linearity is nailed as perfect as can be indicating very precise output levels:
It just doesn't get flatter than this to 20 bits of resolution.
Jitter and noise is as clean as I have seen:
32-tone signal simulating "music" shows superbly low intermodulation distortion:
I almost don't have the hear to show you the next measurement, but I must:
Darn it. Our dreaded ESS DAC chip IMD "hump" is there in full glory. It gets exaggerated ironically with lower noise floor that the SGD1 DAC has. Can't believe ESS has not solve this problem on their own and put it in their datasheets, leaving it to each designer to figure it out one by one.
EDIT: subsequent to this review, the IMD "hump" was resolved by the designer. He was also gracious to provide the fix for anyone to use!
Finally, here are the filter responses with the names on the front panel:
I used the Bric one for my testing.
Thermal Stability
Recently we have discovered a couple of DACs whose performance changes after warm up (sometimes better, sometimes worse). So I thought I test for this before running any of the measurements. Here is distortion+noise as the unit went from cold to 15+ minutes of run time:
There is essentially no change so I did not try to warm up the unit anymore. All the measurements were performed after this test/warm up.
Given the great design skills of Ben, I expected an exceptional DAC and that is almost what we got. There is great attention paid to keeping noise and interference to a minimum. All of this helps SGD1 beat over 200 DACs in SINAD (distortion plus noise)! Unfortunately, courtesy of design quirks in ESS DAC chip, we have rising intermodulation distortion in mid levels. A year ago this would not have mattered since all implementations suffered the same. But now, some companies have solved this or at least mitigated it to a great extent. I hope Ben takes another look at the circuit design and see if he can make the same fix.
Until then, I am going to recommend the Soncoz SGD1. Just not as highly as I could have had without the IMD issue.
As always, questions, comments, corrections, etc. are welcome.
This is the third review I am posting today! If this doesn't get you to empty your wallet and give me all that is there, I don't know what will. ) If are so inclined, please use: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Tks
Sure is, and we see.. if my eyes do not decieve me. USB C, are we slowly moving along in terms of I/O?
EDIT: ESS be like:
Oh state of the art DAC in all metrics? Not with our chip you ain't.
Seriously though, that IMD is exceptional at the lower end, and also at max power. Ignoring the hump, this thing has virtually the best metrics, does it not? And for that price, with that design and such..
Man are devices one-uping one another quickly these days.
Tks
I have not seen a trend toward it. Just a handful of devices support it so far.
Btw that new graph is killer. And for 15 minutes too boot. That should virtually all recent fears folks have. Unless someone makes a case as the heatsink (which in audio I feel like we don't have to worry about because not many from Sabaj even considers putting heatinks on actual chip parts much these days, let alone a case design that acts as a heatsink).
It's really amazing how well the other metrics turned out considering ESS's hibernating selves not peeping the slightest with news of the ESS hump nonsense being addressed on die hardware-wise.
Not that it matters considering it looks like the 4499 is due to obliterate them ESS hump or not.
Amir got a competitor here or a team mate? Well done to both either way, and the manufacturer!
We both have the same analyzer so the question becomes who is better looking. I vote for myself:
Recently shaved the chest hair though as I was getting too popular around here....
Xulonn
Boquete, Chiriqui, Panama
Even a nice little YouTube intro video - dated November 8, 2019...
Celty
Hammer down the ESS Hump, if it really has bluetooth AND wifi put an external antennae on it, and add a remote - and this thing would be killer.
McFly
NZ
What’s the point of the coax digital out? Because there is a streaming board in it? Is it post volume or (assuming digital) pre?
maxxevv
@amirm , another very interesting point to note about this DAC, its not a ESS 9038PRO based device as almost everyone would be expecting from such performance though.
Its a dual chipped ES9038Q2M design. Very much unprecedented performance !
raif71
I would use it, so that I would have the option of connecting my phone or dap that has no coax out to a receiver that has coax in. This way, I would have digital music processed by the receiver. I'm thinking of getting Topping d10 for this purpose. :). Typical usage .... Phone/dap (via usb) -> dac/amp (coax out) -> receiver
Tks
Its a dual chipped ES9038Q2M design. Very much unprecedented performance !View attachment 41916
How many of their chips have this hump nonsense? Goodness..
gvl
SoCal
How could the hump escape the designer with all the drama about it on this forum?
McFly
NZ
Aii, like a USB to spdif converter. But would it’s volume control still be in play ?
gvl
SoCal
Knowing of it and knowing how to address it are separate things.
Yes, but we're now off to another 50 page thread about the hump, it hardly does any good for the product. One would think the issue had to be mitigated before the product was sent for scrutiny here, especially now that we know that the hump can be solved.
bunkbail
