staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,205
- Likes
- 13,201
This is most welcome, I may end up buying this just to check out the nice meters... cheers for the results.As you see, the unit comes in gorgeous packaging with custom and VU meters befitting of some of the highest end audio products of 1980s when such feature was popular.
Minor problem but how did nobody notice it in the testing process? They never plugged their amps in with no source attached? And they 'fixed it' in future models, not current ones.Read carefully:
Both meters work as expected when listening to audio.
Only when nothing is connected to the Amp's inputs, one meter is pegged at max.
Furthermore, the company has since identified the issue and fixed it.
It was variability in one part. They tightened the spec for it.Minor problem but how did nobody notice it in the testing process? They never plugged their amps in with no source attached? And they 'fixed it' in future models, not current ones.
Saw this review on Amazon. Only one review, but reliability issues like Topping and SMSL. Not sure if I can jump into the ocean just yet.
True.It’s tough to know without a true reliability database. $1K gets you in the range of vintage Bryston and Boulder amps, which at least have a track record of performance — but you also don’t know if you have used up the 30 years of longevity in the previous 30 years.
In my experience, comparably priced Class D amps are generally dead silent, even in high-gain mode.You will not hear annoying hiss like you do with many of the Class Ds.
None of the Hypex and Purifi have any hiss. They are DEAD silent.In my experience, comparably priced Class D amps are generally dead silent, even in high-gain mode.
Well built SMPS makes difference.The power stages look to be beautifully made and they have incorporated a shielded custom SMPS. So the problems of hum and mains noise are virtually absent. The mains artifacts are at least 30dB below a decent performing traditional linear supply.
Old-school linear power supply, heavy and costly, are dead.
NAD should take note, this is how you make a more attractive amp
