SpaceX launch their biggest rocket yet- fireworks guaranteed
sarumbear
I sometimes get the impression many journalists simply don't get the thought proces behind this approach.
it used to be you graduate from journalism school to become one. Now, even the editors are not. In general journalist are now the least educated white collar professionals out there.
Martin
Cape Coral, FL
The sensationalism of media is terrible.
SpaceX said this will be a launch test. Their goal is for the rocket to lift from the pad. They wanted to test the engines on load and rocket’s lift from the pad. Any success after that was “icing on the cake.” How was it reported?
“Rocket exploded before reaching the orbit!”
Even reputable sources like FT, NY Times, Guardian including the BBC reported along the same lines, as if it was a failure. It was a bloody success!
This is why we cannot, and should not, trust the media.
Reputable sources? In what universe.
I love that the announcers on the live stream said Starship experienced a RUD (Rapid Unscheduled Disassembly). I love it.
Martin
sarumbear
The English speaking world.
Have you seen him and the others laughing as it was a joke.
staticV3
who is going to clean all the toxic crap they just dumped into the ocean?
The wreckage will be recovered by SpaceX alongside local authorities:
Link with timestamp
The rocket used oxygen and methane as propellant, both of which are gaseous above -70°C, so will not dissolve into the ocean.
The rest of the rocket is solid, presumably insoluble in water, and, being a scrap pile of steel and ceramic, presumably not very toxic.
sarumbear
sarumbear
JRS
Albuquerque, NM USA
media doesn't do science--they are not trained, and most Americans wouldn't know the difference. Personally, I see this as a failure only diminished by a deliberate reduction of expectations--cheering as it self-destructed (probably someone on the teleprompter say cheer). 3 ignition failures and 3 more shut downs is an abject failure by any standard. Let Elon spin it any way he wants. If it were NASA congress, critters would be clamoring for a shut down.
The real tell will be how soon before they fire again. I have no problem acknowledging the success of the booster not crumpling under a dynamic load and getting thru max q seemingly intact, but getting the cluster right should have have been a given. The loss of stability also concerning. Bad luck that all the downed engines are on the same side?
And "unscheduled disassembly"-Really????? An embarrassment of the English language IMO.
sarumbear
They could read the press releases and report accordingly.
Do you also believe Bill Gates had chips in Covid vaccines? :facepalm:
Shame that you fail to understand comedy. Life for you must be sad…
mhardy6647
They carry mainly liquid oxygen and a smaller part methane. It looks bad but is probably insignificant compared to the gas that is flared of every day.
For future launches spaceX plans to generate the methane themselves from green energy.
The rest is mainly steel. The black part is ceramic tiles. And 1 battery pack in the nose cone.
Fortunately, methane's not much of a greenhouse gas. ;)
Plus, it all got converted, rather suddenly, to CO2 (EDIT: plus H2O, of course).
RayDunzl
Central Scrutinizer
Riverview FL
It looks like the launch pad could use a flame diverter and some extra water cooling...
Apollo Frame Trench - one side of the pair under the engines
Steel diverter ramp then a place to go, wall covered with some kind of brick
I guess it rolled into place.
woofersus
FWIW despite some click-baity headlines, (generally not written by the journalists) pretty much every media outlet included the disclaimer that the bar for success was low here and they expect to do many more tests before everything works properly if reading the actual article. I was curious and looked at a few. Misleading headlines are annoying, but it seems like most of the actual journalists covering this did fine.
I watched the video after the fact and it was still exciting even though I knew what was going the happen, lol. I can't imagine being in one of those boats you see near the launch location.
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
