speaker doesnt seems to follow technical specs
mARCELOCM
Hi, i have a setup using a Loxjie a30 + Cambridge Audio SX-50 and i took a measurement from 1m apart from the speaker and looks like this:
is it normal to look like there is no bass at all? if a change the tone settings in Loxjie it doesnt appear to change anything, to my ears it has a minimum more bass but little more distortion too.
sx-50 specs:
SENSITIVITY87dB
FREQUENCY RESPONSE50Hz-22kHz
IMPEDANCE8 Ohms compatible
RECOMMENDED AMPLIFIER POWER10-100 watts
DRIVERS5.25” (135mm) treated paper cone woofer 1” (25mm) Silk dome tweeter
CROSSOVER2 way
PORTED1 rear
MAGNETIC SHIELDINGNo
COLOURBlack or walnut
DIMENSIONS (HXWXD)225 x 161 x 240mm (8.9 x 6.3 x 9.4")
WEIGHT3.0kg (6.6lbs)
M
mARCELOCM
Looks like your window size is too small.
sorry, i dont understand, my window?
i see that the speakers maximum output is at 200hz, but its supposed to be high until 63hz, in the case it roll off too much below 200hz
Sokel
Doesn't seem strange considering the specs of your speakers and the usable 18 watts @8 Ohm of your amp.
sam_adams
M
mARCELOCM
Seems like its the higher window solved, the new measurement:
