Speaker driver beaming frequency formula
Music1969
Hi all
I saw this below formula for calculating speaker driver beaming frequency for driver diameter but when I saw this video by Danny, his numbers for various driver sizes don't match my spreadsheet.
Watch Danny from 7 minutes to 8 minutes. Can anyone help with the correct formula?
Thanks!
Jim Matthews
Taxachusetts
I thought beaming began when the wavelength produced is less than the diameter of the cone.
Using centimeters:
(Speed of sound) 34400/(Diameter of 8 inch cone)20.32 = 1673 Hz.
Your spreadsheet returns 1074 Hz.
15 inch returns 902 Hz off my Math.
Rick Sykora
Stow, Ohio USA
Using centimeters:
Will just add that the significant variable here is the cone diameter. The effective cone diameter of a driver is smaller than the driver‘s physical size. For example, have seen others use 17 cm for an 8 inch driver.
Jim Matthews
Taxachusetts
Will just add that the significant variable here is the cone diameter. The effective cone diameter of most drivers is smaller than the cutout. For example, have seen other use 17 cm for an 8 inch driver.
That returns a "start of beaming" threshold of 2023 Hz - double the OP spreadsheet!
Rick Sykora
Stow, Ohio USA
Yes, the calc is more a rule of thumb. Tend to use the actual driver off-axis measurements for specific design. :cool:
Jim Matthews
Taxachusetts
Yes my spreadsheet formula is same as yours x (2 / pi)
Why do you apply those multipliers? They're the source of your discrepancy with DR's video.
M
Music1969
Is it anything less than omnidirectional?
Good question, I'll say this quoted, to keep the discussion a bit simpler.
I definitely appreciate things can get very complicated quickly
Jim Matthews
Taxachusetts
I believe the article is misdirecting your attention. It proports to deal with lobing, where adjacent drivers *might* begin to interfere with each other at a given separation.
Practical crossover design employs the fewest parts to achieve the smoothest transition between drivers. Using your calculator would (effectively) double the number of drivers required.
M
Music1969
Noted. It mentioned beaming specifically and only difference with your formula is (2 / pi) factor:
M
Music1969
Here they are talking about a simple 2-way design as an example
I guess this formula is more conservative (2 / pi = 0.64 factor) so no harm , if you can find the correct driver?
astrex342
One discrepancy may be due to the "inch" number or the driver not actually being the diameter of the sound recording surface.
The inches in drivers is usually the total diameter of the woofer flange, or the diameter of the screw holes. The actual sound radiating surface is usually an inch or two smaller.
Take the example of the Scanspeak illuminator 6 inch. The actual sound radiating diameter is 108mm or 4.25 inches. The 150mm or 6 inch refers to the woofer flange diameter.
Therefore, I think the formula and the video are both correct. But to use the formula correctly, you should use the actual sound radiating diameter. It can be calculated with 2*(Sd/π)^0.5
M
Music1969
I think you're right.
That website where I got the formula shows an example with 6.5" Seas: http://www.seas.no/images/stories/prestige/pdfdatasheet/H1215_CA18RNX_Datasheet.pdf
But in their example they state "effective diameter of the driver is 13.16 cm so 0.1316 m" even though 6.5 inch is 0.1651m
M
Music1969
Ok working backwards to workout their example they've used this from the Seas spec sheet to calculate effective diameter, and then plugged into their formula
M
Music1969
So I think this is solved
f = (2 * c) / (π * D)
Where :
  • f = frequency where the speaker starts to beam (Hz).
  • c = speed of sound (343 m/s).
  • D = effective diameter of speaker (m) = calculated from effective piston area on driver spec sheet
hardisj
Reviewer
North Alabama
Beaming = speed of sound / driver effective diameter / 2
effective diameter = half surround to half surround
divide by 2 to get half wave
some will divide by 4 but 2 is close enough and makes more sense when talking about CTC spacing.
