Speakers and AMP for 2.1 setup under 500€
Bucking
I've been looking for suitable speakers plus AMP/DAC/Receiver for a small *2.1* setup for the TV (I already have a subwoofer).
Price-wise, I could spare up to 500€ and am definitely willing to buy used. I'm located in Germany so not everything is available to me.
After looking at some tests and reviews on ASR/Youtube/Etc., I'm almost more undecided than before due to the many different opinions and amount of products that are out there.
Are there any recommendations from you (I won't be upgrading to 5.1)
Ellebob
A DAC with volume control and remote like Topping, SMSL, Schiit, etc. or Wiim Pro if you want streaming under 200. Not sure what's available in your area pricing.
Then studio monitors like Kali, JBL, etc.
staticV3
@Bucking I'd look for a pair of active studio monitors. Here's a list of good ones in your budget: Link
To connect them to your TV and create a 2.1 setup, you could use:
-SMSL PS100 with RCA splitter cables (volume controlled by your TV remote)
-WiiM Pro/Pro+ with splitter (WiiM remote for volume, 4-band PEQ for room correction)
-SMSL M300 SE (SMSL remote for volume, separate XLR and single-ended output so no splitters required)
staticV3
If you'd rather buy a receiver with passive bookshelf speakers, then here are some good options:
Model
Preference Score
(higher=better)
Price per Pair
Klipsch RP-500M II​
5.2​
450€​
Elac Debut 2.0 B6.2​
5.0​
230€​
Polk ES20​
4.7​
300€​
KEF Q150​
4.6​
400€​
Mission LX-3 MKII​
4.5​
250€​
Klipsch RP-500M​
4.4​
300€​
Polk XT20​
4.1​
220€​
Polk S15​
4.1​
200€​
Polk XT15​
4.0​
130€​
Q Acoustics 3020i​
3.9​
250€​
B
Bucking
So I found some Kef Q350s for 220€ on the used market would that be something to consider?
Also would the Loxjie A30 be sufficient for driving them?
staticV3
Here are Amir's measurements and listening impressions:
The Loxjie A30 can drive a single Q350 to 100dB SPL (anechoic 1m).
With a stereo pair and moderate room reinforcement, you're looking at:
106dB SPL Peak @1m
100dB SPL Peak @2m
97dB SPL Peak @3m
Whether that's loud enough for your needs, I can't say.
B
Bucking
106dB SPL Peak @1m
100dB SPL Peak @2m
97dB SPL Peak @3m
Thank you very much I think 220€ for a pair is definitely worth it considering the score they have.
Seems to be loud enough for me
B
Bucking
Or is there anything like the Loxjie that would be better at around 200€?
Willem
Yamaha AS201? However, I would save for the Yamaha AS301, with subwoofer output and digital inputs. It is a tried and tested design and should be far more reliable than most alternatives. As for speakers, for a secundary system I recently bought a pair of Wharfedale Diamond 220s for some 130 euros and they sound very good as was to be expected from Amir's test. They are a bit bass light, but the bass that there is is clean.
B
Bucking
So I found a used Loxjie for 130€ and a used AS301 for 200€. Do you think the 70€ extra are worth it?
Willem
Absolutely (if it is the ASA 301 and not the AS300). You get about three times more power compared to the Loxjie and that makes for a rather cleaner sound with dynamic music. Plus, you get goodies like tone control etc.
B
Bucking
Thanks for the information
What about the Aiyima A07 Pro and MAX/Fosi V3 these should also have enough power right?
delta76
used avr + DBR62 should work the best for you. If you are lucky, maybe you can find a denon x3300h/x3400h for EUR200 and then the rest to DBR62
B
Bucking
So I got the Kef Q350s for 210€ now I'm looking for a good amp :)
B
Bucking
I'll probably go for the Yamaha that seems to be the best option
B
Bucking
The denons are all above 350€ :/
delta76
as I said, if you are lucky. buying used is finding the best deal, that takes time and patience.
you can try your luck with older versions, but I would go with x3400h as it has Audyssey xt32, eArc, 4k HDR etc. perfect to use as the center of your multimedia corner
