Split DAC USB
NiagaraPete
Can I use a hub for multiple USB sources into a DAC?
Trell
It would surprise me if an USB DAC supported that as it would have to have host functionality as well as user interface to select among the connected USB sources for playback (or play everything mixed from all sources).
Killingbeans
Bjerringbro, Denmark.
@Seeker-Smith Don't think so. A hub allows one host to have access to multiple devices, but not the other way around?
I think what you're looking for is called a 'USB switch'.
NiagaraPete
NiagaraPete
Okay so I’ll need a switch vs a hub. Thanks!
