It would be an odd thing to fake. But there is a contact email on the site - why not contact them to ask.Who said this test is reliable ?
What do we know about the files used in it ?
Yes I replaced compressed with lossyIn practice, all streamed files music will be compressed. Losslessly or lossily, there's the difference.
Nice!I have occasionally blind tested wav vs 128 kbit (converted by myself) with the Foobar abx comparator. Usually I have managed to get 20/20 results, but it has required concentrated listening. In most cases the difference is far from obvious. Could I enjoy listening the lossy version? Sure.
Which converter did you use? (All mp3 converters are equal, but some are more equal than others )I have occasionally blind tested wav vs 128 kbit (converted by myself) with the Foobar abx comparator. Usually I have managed to get 20/20 results, but it has required concentrated listening. In most cases the difference is far from obvious. Could I enjoy listening the lossy version? Sure.
Only 320 kbit. No chance.Nice!
Did you try to up the bit-rate to see when you can not hear the difference anymore?
I used Lame, supposedly the equalest of them all.Which converter did you use? (All mp3 converters are equal, but some are more equal than others )
To me the biggest difference with lower bitrate MP3 is that lowpass filter (which is at maybe 15khz at 128kbps afaik?), and if you're older than say 50 you won't hear over that frequency anyways. Don't know how old you are but I guess that might be the reason. Of course it's possible to hear other artifacts as well, but some samples are easier to encode than others.Just out of interest, I just tested myself on the 96kb/s lame MP3 vs lossless - I only got 76% correct.
Two of the tracks I was just guessing. I'd be guessing on all of them at 320. Probably even at 256.
(Speakers, not headphones)
Driving their car in the kitchen? That's a new one!To me the biggest difference with lower bitrate MP3 is that lowpass filter (which is at maybe 15khz at 128kbps afaik?), and if you're older than say 50 you won't hear over that frequency anyways. Don't know how old you are but I guess that might be the reason. Of course it's possible to hear other artifacts as well, but some samples are easier to encode than others.
But yeah, 320kbps OGG Vorbis is a totally different story, would be interesting to see a study on that and to have something to throw in the face of people claiming their wife hear a night and day difference from the kitchen when listening to an iPad in their car driving at 100kmh.
Yeah you know audiophiles living in enormous mansions with really large kitchens!Driving their car in the kitchen? That's a new one!
62 and I can hear test tones up to about 13.5Khz.To me the biggest difference with lower bitrate MP3 is that lowpass filter (which is at maybe 15khz at 128kbps afaik?), and if you're older than say 50 you won't hear over that frequency anyways. Don't know how old you are but I guess that might be the reason. Of course it's possible to hear other artifacts as well, but some samples are easier to encode than others.
Yup it does: https://wiki.hydrogenaud.io/index.php?title=LAME#Technical_information62 and I can hear test tones up to about 13.5Khz.
I was not aware though that lower bitrate MP3 implemented low pass filters below 20Khz.
The other highlighted stuff is that specific groups could identify differences between cd and mp3 according to another study that this study references. And in general it discusses audibility capacity among different groups of people especially those acquainted with the natural sounds of musical organs . My aim is to show the ambiguity that exists in this matterA bit unclear text in that study. And unclear what point you are trying to make as well since you are just posting and highlighting the study with no comment.
The study says "These overall results demonstrate that mp3 compression does introduce audible artifacts."
While what it should have said based on their own study results is: "These overall results demonstrate that mp3 compression does introduce audible artifacts at 192kbps or lower, while at 256kbps or higher, the study has not proven this to be the case."
It is highlighted in my attached photo . Sutherland studyDo you have a reference/link to that study then?
Citation number 8 you can search in the original link
I think it's here in optimum_bandwidth() in lame.c:That's only for variable bitrate though, can't find info for constant bitrate
const band_pass_t freq_map[] = {
{8, 2000},
{16, 3700},
{24, 3900},
{32, 5500},
{40, 7000},
{48, 7500},
{56, 10000},
{64, 11000},
{80, 13500},
{96, 15100},
{112, 15600},
{128, 17000},
{160, 17500},
{192, 18600},
{224, 19400},
{256, 19700},
{320, 20500}
17000 * 2 / 44100 = 0.771
23 / 31 = 0.742
24 / 31 = 0.774
therefore stop-band starts at:
24 / 31 * 44100 / 2 = 17071
and transition-band starts at:
(24 - 0.75) / 31 * 44100 / 2 = 16538
]$ lame -b 128 test.wav test.mp3
LAME 3.100 64bits (http://lame.sf.net)
Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
