Steep treble rolloff on both Energy V-S rears
ratnermi
I have old Energy V-S surround speakers (beautiful-looking and fairly expensive) mounted high on the back wall. They never produced much sound but I guess I wasn't paying attention... recently I got a UMIK-1 and REW and measured their room response. Do you have any idea what could be causing such a steep rolloff in the treble? They actually have a knob for gain on each speaker, and this graph is with the knob turned all the way to the right. The mid position on the knob produced a graph with a much steeper rolloff.
It's not tweeter dispersion, because I measured them at different room locations with the same result. It's not one speaker's blown tweeter, because, as you can see, both exhibit the same behaviour.
Any clues as to what's going on, and how to fix it? TIA.
Here is the speaker description page: https://www.energy-speakers.com/products/surround-speakers/?sku=V-S
Twelvetone
Was this curve taken in dipole or dipole mode? Does it shut off (or pad) the tweeter in dipole mode?
R
ratnermi
I tried it both ways, in dipole and bipole modes. The curves are very slightly different between the two, but nothing major. Certainly the rolloff slope didn't change.
fpitas
Northern Virginia, USA
It's almost like the tweeters are bad, or turned way down.
LTig
Europe
Which mode dId you set in REW? You may need to use RTA.
staticV3
If you use pink noise as test signal, then you need to set the RTA Mode to RTA instead of Spectrum.
If you use the regular measurement sweep, then this does not apply obviously.
R
ratnermi
Frankly I don't know, what is RTA? I just used the defaults as per various instruction videos, etc. Only the rears exhibit this behavior among the 7 speakers.
staticV3
Right, so?
Your measurement look normal up to 2.5k.
The Xover being at 3k makes the tweeter just playing too quiet a plausible cause, rather than some other fault.
I see the surrounds are bi-ampable. Have you confirmed that there are metal strips in place, bridging the two sets of binding posts?
If they're gone and only the woofer is connected, then that could explain the measurements.
Edit: Ah it's probably just the mains that are bi-ampable. The Manual combines the entire surround setup, so I got confused which graphic represents which speaker type.
R
ratnermi
That would have been an awesome simple solution! But where do you see that they are bi-ampable? Here is the picture of the back:
and from the cut sheet:
"Inputs Single 5-way nickel-plated binding post"
R
ratnermi
Reporting back: nothing worked. I swapped their line inputs with the sides, no change. I physically removed the speaker from the rear wall and moved it to the front, connected the FR speaker wires to it, no change. Listened to the 10Khz tone, nothing is coming out of the tweeter. Switched + and - wires just in case inputs were mislabeled- no luck.
They are quite sophisticated speakers: 3-way, switchable between bipole and dipole, dual midranges. Thinking to send them in for repair.
