Stereo receivers, amps, and preamps with XO that include high-pass filter for the main speakers?
K
KEW
Meaningful questions. A few quick thoughts ... from what I recall dyes are used to produced color in anodized aluminum. Pure black will absorb all visible wavelengths, however (1) dye that looks black will most likely reveal a different chromatic absorption spectrum if a prism or similar thing is used to view the light that bounces off it (2) even if the dye is a perfect absorber of all visible wavelengths it won't much matter unless the fins get way hotter than you would hope they would get - a stove burner doesn't begin to glow visible red until it is much too hot to touch (3) the thermal conductivity of aluminum oxide is only about 1/8 as great as the thermal conductivity of pure aluminum, so by anodizing it you would in effect be coating it with a thermal insulator (4) an object that absorbs all visible wavelengths has properties akin to a "black body" but is not necessarily a "black body" in the sense used by physicists.
The concept of a "black body" is defined from the perspective of absorption, denoting an ideal (i.e., hypothetical) object that absorbs every quanta of incident EM radiation irrespective of wavelength or incident angle. If particularly-defined equilibrium conditions are met a black body will reradiate the energy it absorbs. Since the thermal energy that is desired to be radiated from the heat sink is predominately long wavelength (longer than visible wavelengths), if the heat sink fin were a true "black body" it would be somewhat analogous to using an RF amplifier for audio. "Black body radiation" refers to radiated EM energy wherein the spectral makeup is that of an ideal "black body" at some specific temperature, i.e., the spectral distribution obeys the mathematical formula discovered by Max Planck.
WARNING: the following train-of-consciousness discussion of the historical roots of quantum physics is intended only for people who are not annoyed by other people's train-of-consciousness discussions of the historical roots of quantum physics.
The black body concept and related concepts are interesting because quantum physics has its historical roots in the effort by physicists to explain why hot objects do not radiate energy in a manner uniformly distributed over wavelength, i.e., why the color of a hot object changes from red to white to blue as the temperature increases. As far as anyone could figure out, as the end of 19th century was looming near, there wasn't any reason why a hot object ought not emit white light (uniformly distributed over wavelength) that merely increases in intensity as the temperature increases. Max Planck figured out the statistical formula that matches the experimentally observed spectral distribution. His formula "explained" why the emitted radiation was predominately long wavelength (red) at low temperature and why the spectral balance gradually shifted toward shorter wavelength as temperature increased. But why did nature favor that mathematical distribution, asked everyone. Someone, presumably Planck, pointed out that the only way the formula could be explained would be if energy were only radiated in discrete chunks, i.e., quanta. At low temperature, comparatively few short-wavelength quanta are possible (compared with what is possible at higher temperature) because short-wavelength quanta carry off a lot more energy than long-wavelength quanta. The idea that energy consists of discrete quanta was so radical that not many physicists were bold enough to say that this really did mean what it meant. Another major problem that physicists had been trying to explain was the photoelectric effect. In particular, why it was that low-intensity UV light could stimulate electrical current but a high-intensity red light could not, no matter how great the intensity. Einstein used Planck's theory of black body radiation to explain the photoelectric effect and was awarded a Nobel for the explanation. (He was awarded a 2nd one for his theory explaining Brownian motion, which settled the question of whether atoms were real, which question was still unsettled at the start of the 20th century. He was never awarded a Nobel for either of his two theories on relativity. The first theory of relativity, the explanation of the photoelectric effect, and the theory of Brownian motion proving the existence of atoms were all published the same year, 1905, while he was still working as a patent clerk.) Einstein explained that quanta of red light don't carry enough energy to make orbital electrons take the leap from one atom to the next atom, and that when intensity is increased, this only increases the quantity of quanta that are too weak, whereas individual quanta of UV light individually possess enough energy to make it happen. The next major player was Bohr, who realized that the quantum nature of energy was the reason that the elements all had their very particular and unique absorption spectra. This insight along with years of determined effort permitted him to come up with his atomic model where electrons orbit not in an any-orbit-is-as-good-as-another fashion (a Newtonian, planetary fashion) but rather in a fashion where only certain particular orbits were permitted, each with its own particular energy level, such that the energy difference for an electron jumping from one allowed orbit to another allowed orbit matched the energy of the emitted/absorbed wavelengths of an element's emission/absorption spectrum. At some point someone pointed out (maybe it was Bohr but I don't recall) that if you apply Einstein's most famous formula to the mass of the electron to obtain the equivalent energy and then apply Planck's constant in the equally routine manner to that amount of energy, thereby calculating the electron's physical wavelength, that the allowed orbits in Bohr's model are those orbits where the circumference is an integer multiple of the electron's wavelength, such that an electron orbiting an atomic nucleus may be considered to be a sort of standing wave. (The orbital circumference is a trivial Newtonian calculation using the electron mass and kinetic energy.) Interesting it is that for electrons moving through space the particle model is ideal whereas electrons that have been captured by an atomic nucleus are best modeled as standing waves.
You were warned not to read past the warning.
Thanks for the lesson! I feel the power of knowledge! ... (as in I "know enough to be dangerous")
Modellbobby
Hey gents and lady’s ,
What is now a good stereo+sub streaming amp or amp with high pass filter next to the low pass for the sub. I read the whole thread but nobody came to a conclusion yet
Head_Unit
It is simple enough to add a capacitor inline with the speakers.
To riff on @waynel this doesn't work well, I had to redesign a produce like that and found it's a really crude and crappy approach. At the lowest frequencies yes there is some cut. But the speaker's impedance peak at resonance messes things up.
sigbergaudio
Norway
Idiocratease
I came across this thread and though I would share my journey/set up.
I have tried music with a sub in the past, but never was able to be totally happy with the integration. I have learned since that the likely problem is time alignment, and most integrated stereo amps dont to this, certainly my Classe Sigma 2200i does not, but it does have quite flexible digital crossover options, and assignable configurations for e.g. Music sources vs movie sources… so nicely allowing me to play music without the sub, then switch over to movies and pick up the sub automatically. This is a solution I used for a little while…
There is however the additional problem of how mulit-channel is mixed to 2.1. On listening and then googling, I find that typically much of the real LFE from movies is ditched in the mixing to 2 channel, so when going to 2.1 in the amp, you miss a bunch of the real LFE. I think their through process, when they design the mixing, is that likely the 2.0 systems would not be able to handle true LFE signals from (i.e. Most people stereo speakers aren’t handling high power 15-30Hz signals !)
So I realised that while I was getting good 2channel from Multi channel (I.e. good amp and good speakers), but I was missing the juicy LFE signals from movies.
Fortunately I have a fix
You see in the photo to the left in a cabinet, a silver unit. This is an OPPO BDP-105D. This is a flexible Blu-ray player which also acts as a DAC and DSP. So I take the TV’s toslink multichannel digital signal into the OPPO, mix multi channel to 2.1 (select small speakers). Set the crossover (my case 50Hz), set the time alignment on the speakers, and then take the now muxed 2.0 channel signal (digitally) from the OPPO to the Classe Sigma amp (using HDMI, so all this is done in digital domain), and take the analogue RCA subwoofer signal into the subwoofer, which has it’s own AB amp built in.
So now I have pure 2.0 for music, for films I have all speaker (except sub) digitally mixed to 2.0 and a properly separated .1 sub sent to the sub.
What is interesting maybe for users is, though my amp has a sub out, in fact I don’t use it, so a set up like this you actually dont need a 2.1 amp.
you just need a dvd or BluRay player with the kind of options to act as a stand-alone DAC/DSP like the Oppo DBP-105d.
maybe this is off topic, but I thought close enough to the issue to share….
telemike
Elac has a nice 2.1 setup with DSP LPF/HPF
Through the use of the free iOS and Android app the user first selects a high-pass filter, then using the smartphones microphone, measures the near-field response of both the main speakers and subwoofer. Our proprietary algorithm then adjusts the low pass filter to obtain optimal blending between the subwoofer and main speakers. Auto EQ minimizes the effects of the rooms acoustics allowing you to hear the sound the designer intended.
