Stereophile has started calculating EPDR.
MZKM
Land O’ Lakes, FL
https://www.stereophile.com/content/goldenear-brx-bookshelf-reference-x-loudspeaker-measurements
And he is going back to previous reviews and adding this in.
EPDR (Equivalent Peak Dissipation Resistance) takes the impedance and phase data and computes a new impedance that shows what equivalent load the amplifier will see. This takes the guesswork out of knowing how an amplifier will handle a given speaker if we have measurements of that amp into low impedance.
For example, in the BRX link above, here is the raw impedance & phase:
The raw impedance never goes past 3ohm. However, at 135Hz where the impedance is ~5ohm and the phase around -45°, the EPDR is 1.53ohm, over 3x lower.
This is something that I believe would greatly benefit Amir’s reviews, we just need to know the calculation.
For those providing EQ adjustments to speakers measured here, it would also be interesting to see how they effect the EDPR.
QMuse
REW calculates EPDR in Impedance & Phase graph since version 5.20 beta 46.
M
MZKM
Land O’ Lakes, FL
Is the formula available?
I want to include this in my speaker data files, and it’d be easier if I can just calculate it in the spreadsheet and not have to go into REW.
Wes
What is the EPDR for a Magneplanar 3.7i ??
CDMC
tjf
Silicon Valley, CA, USA
If like most Maggies, very close to the impedance, as they have very low phase angles. Maggies are inefficient, but not current hungry.
https://www.stereophile.com/content/magnepan-magneplanar-mg36r-loudspeaker-measurements
And...there's the argument for 1st order (open baffle) and 2nd order (sealed box) bass driver/enclosure alignments....
With 3rd order (aperiodic/damped port) alignments coming in next....phase-angle-wise, that is....(3rd order alignment example in memory of Bud Fried and the transmission-line crowd...)
phoenixdogfan
Nashville
Peter Aczel used to do something called the "Power cube" which displayed the voltage output at varying level of impedance and phase angle.
An example.
http://www.biline.ca/audio_critic/audio_critic_web2.htm#ba
For the notorious Behringer A500 which as can be seen performs fairly well in this test.
I've always thought ASR's (or for that matter Stereophile's) amplifier reviews would be enhanced by this measure.
pozz
Слава Україні
Editor
An example.
A PowerCube is around $20k, if I remember correctly.
https://www.audiograph.se/
Head_Unit
the "Power cube" I've always thought ASR's (or for that matter Stereophile's) amplifier reviews would be enhanced by this measure.
https://www.audiograph.se Lars is a very cool guy, we had dinner with his wife in Vegas long ago. I got the humongoid audio claptraporation I worked for to buy a couple for amp testing. They are like $10-20k or something like that.
Really a next-level test for amplifiers, sometimes showing truly ill behavior. I would have preferred probably 70 Hz but Lars said the physical parts to do that would get crazy big and expensive.
As for
...EPDR is published in AES paper "Audio Power Amplifiers for Loudspeaker Loads" written by Benjamin Eric (Dolby Labs).
- Here's a related link https://www.stereophile.com/reference/707heavy/index.html
- I think I have Eric's paper in my garage but it's too damn hot to look for it. Is that the one where he's using a oscilloscope to look at peak loads?
- And maybe the same question or maybe not: does it actually work? If you put in that frequency signal, is the current draw actually what it would be with the EPDR resistance? (Yes, theory says so, but speakers are funny beasts and it's nice to check reality)
It is a bit cheaper. For a stereo, 1000 watt it is $15,000 plus $1000 for the travel case and shipping/customs clearance.
The cheapest is 1 channel, 500 watts for $11K for the system itself.
Supported Test tone is only 1 kHz which is limiting.
Head_Unit
I recall now Lars said he was working on making an "active load" which would get around the limitations of huge physical parts for low frequencies. Maybe an amp acting as a kind of load? I guess that never worked.
Hmm, to check ballpark values I randomly pulled up an impedance calculator which shows 1000 microfarads is like 2.2 ohms at 70 Hz.* And those don't seem crazy expensive...though for 400 watts at 8 ohms you need maybe 60 volts...well that's RMS so times 1.414 then times 2 so like 180 or call it 200 volts. Meanwhile a 10 mH inductor I get 4.4 ohms at 70 Hz. Those don't seem crazy expensive but I don't know about the current handling. Is the voltage/current why it would get expensive to make a hand load? Or am I calculating wrong?
I'm sure a large chunk of the Power Cube expense is the automation, and the multiple loads, and of course a large profit margin to support a small sales quantity.
*I randomly pulled 70 Hz out of my butt as a non-integer multiple of 50/60 Hz. If I was going to set up this testing I'd want to run FFT of the distortion spectrum at clipping, and so use some frequency and FFT setup such that 50/60 Hz mains bleed and the test signal would be in different FFT bins for at least the lower harmonics.
hardisj
Reviewer
North Alabama
Anyone ever find the calculation for this? I would be happy to implement it in my reviews if it's useful. But I don't have time to hunt the equation down or the like.
Martin
Cape Coral, FL
Read the thread. The link is in the 4th post. You need to buy the paper to get the formula.
Martin
pozz
Слава Україні
Editor
@MZKM Did you get to adding this to your tables?
M
MZKM
Land O’ Lakes, FL
Amir has not added this data (and I’m not going to use a digitizer on his plots every time). Also, he said he isn’t too keen on it as it makes high frequencies seem worse than in actuality (less energy up there so being difficult to drive isn’t an issue).
Oh, and I’m not paying for the formula, so unless someone already is able to access it, I would have to use REW every time to import/export the data, which would be annoying.
pozz
Слава Україні
Editor
Ah well.
Would have been an interesting single-number figure to add to the dataset.
hardisj
Reviewer
North Alabama
Martin
My bad.
Well, if anyone happens to get their hands on a copy and can share the formula, please do. It should be easy for me to add this since I already export the impedance magnitude/phase data in to a .txt file anyway.
jackocleebrown
Hi Everyone,
I sent this to MZKM yesterday but just noticed this thread today. Please see attached. You can skip everything and jump to the last equation showing the formula for calculating EPDR from impedance magnitude and impedance phase magnitude.
Just a note of caution that the EPDR derivation is based on a class-B output stage so it's valid for typical class-AB amps but certainly not for class-A and probably has only marginal relevance for class-D amps (would love to hear from a class-D expert on this topic).
For your background, the Benjamin Eric paper includes a thorough analysis of how to relate the speaker load to the amplifier dissipation but it's actually Keith Howard himself who invented EPDR as a cleaner way to present the data. I don't think that Keith has ever published the final calculation so when I came to want to do this myself I had to re-do the derivation and check with Keith that it matched his calculation.
The PDF is from my raw notes and was never intended for publication. It's a bit rough but seems like there's enough interest to justify me posting in this form.
Kind regards,
Jack.
  • EPDR sketch2.pdf
hardisj
Reviewer
North Alabama
Hi Everyone,
Kind regards,
Jack.
Thanks for sharing with everyone.
I’d also be interested in knowing more about how this relates to amplifier topology as implementing this metric in a review for readers/watchers using different gear would be a bonus for reviews.
