Studio monitor speakers without hiss?
quorzar
Hello,
because of the measurements, I bought the JBL 305P Mark II for my desktop. The problem is, that Im very sensitive with noise, but I wanted to give them a chance.
At the end I sent them back because of the hiss.
1. What measured speakers are dead silent?
2. Are there some silent ones in the same price range with similar performance? (max. 250$/speaker)
QUO
restorer-john
Active speakers are noisier than passive for the simple reasons they are generally connected directly to the amplifier that drives them. The tweeters don't have a passive attenuating network that is present in non-powered speakers. The other reason is the quality of the amplifier driving the treble units in active speakers. Generally, they are as cheap as they can get away with and overall power in compact package is the goal, not low levels of residual noise.
Skip the active route, buy some passive speakers you love and an amplifier with very low residual noise and all your hiss problems will be history.
Bear in mind, no amplifier is dead silent, they all have some residual noise, but amplifiers like the Benchmark take the noise to very low levels.
Wayne A. Pflughaupt
Corpus Christi, TX
The first clue should have been the pitiful published noise spec of a mere 75 dB A-weighted. By comparison, Audio Engine rates the A5+ at 95 dB A-weighted.
Thus you might have to up your budget if you want quiet active speakers.
I can’t find a noise spec for my old Swans M200, but they are dead silent.
Regards,
Wayne A. Pflughaupt
q3cpma
France
Hello,
QUO
Yamahas HSx are dead silent.
sergeauckland
Suffolk UK
If you don't mind used, you should be able to get some Genelecs for that sort of budget. My 1029a are very quiet, I can just hear they're on with my ear against the drivers. I have had some Adams which were also very quiet. As Wayne said above, I think you'll need to up your budget or buy used, as really quiet Pro monitors tend to be more expensive.
S
Purité Audio
Industry Insider
Barrowmaster
London
The actives I have here are totally silent.
Purité Audio
Industry Insider
Barrowmaster
London
You must try and hear some decent speakers John.
restorer-john
This is the key. Powered speakers, desktop distance and a sensitivity to noise:
I would suggest the OP listens to the absolute quietest standalone amplifier he can find (residual A-WTD noise in uV) along with some speakers he really likes, preferably not super efficient ones, and does that in a desktop/near-field environment like his own usage scenario, in the quiet of evening or away from the hustle and bustle of a demo room or noisy city HiFi store.
Forget loud demos to de-sensitize your low level hearing often used by dealers (not always deliberately). Just turn them on, sit down and listen in peace.
All amplifiers make noise, but some a really terrible in that respect, especially the amplifiers in many powered speakers.
2020
Genelec is one if the few that reports this stat as "self generated noise".
Ilkless
Singapore
The problem is there are almost no passives in the budget price range that approach the sophistication - in terms of dispersion control - of budget actives like the Kali LP-6 and LSR305mk2. Except maybe the KEF Q-series.
The LP-6 has amps, and a DSP chip managing the crossover and other functions like boundary adjustements, and costs $149/pc. Passives would be a much easier recommendation if there were more $149/pc speakers that actually exploited the BOM savings of not having electronics on superior acoustic performance (hiss notwithstanding) - think beefier drivers, crossovers worth a damn, directivity matching and so on.
Daverz
My NHT Xd also produce audible hiss. DSP by DEQX and amplification by PowerPhysics. I thought that there would have enough advances in DSP hardware and amplification in the past 15 years that this would no longer be a problem.
Sancus
Neumann and Genelec both have self-noise levels that are inaudible past 6 inches or less, and they provide a spec on it as well. Neither can be described as on the same price level as a JBL 305P MKII.
If you want the best frequency response, dispersion, all without any self-noise you pretty much have to accept higher prices than $150/speaker.
LeftCoastTim
Hello,
QUO
1. My KH80 are dead silent (well, its self noise is barely noticeable with my ear against the tweeter).
2. I think it would be too hard to build one at that price. JBL LSR305 uses an STA350BW chip amp with DSP, which is a $4 part. Unless ST makes a low-noise version of the part, it doesn't seem likely.
restorer-john
There is nothing "high fidelity" whatsoever about audible hiss. It is against everything high fidelity has been striving for for the last 70 years- the reduction of extraneous noise.
There is no excusing it or explaining it away with hand waving about DSP and multiple amplifiers.
LeftCoastTim
There is nothing high fidelity whatsoever about audible hiss. It is against everything high fidelity has been striving for for the last 70 years- the reduction of extraneous noise.
I think studio monitors are work horses designed to a price point.
gvl
SoCal
I seem to remember reading complaints about them hissing. In the same discussion the concensus was that only higher end monitors are quiet and alse specd for noise levels. I also want to move to active for my desktop setup but no ready to drop 2 large on a couple of small boxes. I'm using JBL 104s on my desk now, almost no hiss with the volume knob to the left of 12 o'clock but want something better, plus I hate them egg shaped as I can't put anything on top.
majingotan
Laguna, Philippines
Zero hiss with my Yamaha HS7 as you can see that my room background noise is about 31 dB and pointing my watch literally next to the tweeter didn't do anything. I play at around 77-80 dB average SPL at 2 feet away from tweeters and at this listening volume, I can hear the really quiet orchestra section from Pink Floyd's eclipse track which is a testament to very low noise floor of the HS7
