NorthSky
- Joined
- Feb 28, 2016
- Messages
- 4,998
- Likes
- 947
Not cars Frank, threads.
The overall soundquality is not as perfect in low latency mode as it is in normal mode (most notably only in the low end), but still provides a very pleasurable listening experience for your TV.
What about the phase?
Is your system getting the phase and timing right? If everything 'lines up' isn't that going to be more important than the absolute level of subsonic frequencies?
Phase correcting the bass implies large FIR filters and higher latency presumably..? For example, the Kii Three in normal operation has 90ms latency, but also has a low latency mode for real time monitoring.
It is more helpful if you can post 1/12th per octave or higher smoothing.
Something like this Michael:
They look smoothed to me. I guess it all looks really good then except the big dip which is likely a boundary. At what sample rate are you recording your logsweeps?No smoothing applied (above, Post #1, 5, 7).
I was referring to the sample rate not the logsweep duration. It all looks pretty good to me except the two dips. Those are caused by boundaries.Heres's a full sweep, with 1/48 to clear the hash at high frequencies, same scale as the posts above...
Fastest sweep (128K), because I haven't seen it make much difference in the SPL traces, and 48kHz sample rate.
Prove to me the stupidity and ignorance of such systems (separate quad towers) Michael.
Why do you post this stuff?
Everyday you're excited about something new...
Your measured in room performance is exemplary here for the most part.
Does the frequency dip coincide with the distance between your speakers. I have seen that sort of effect with dipoles before. Something around 11 to 12 feet between speakers would fit.
