Swan Hivi X3 Review (Active Monitors)
Rate this speaker:
    Votes: 88 53.7%
    Votes: 67 40.9%
  • 3. Fine (happy panther
    Votes: 7 4.3%
    Votes: 2 1.2%
voodooless
Netherlands
It should have been called Genelegg
Clearly they have not followed the design details of the Genelec. Genelec speakers are actually quite squared, with rounded edges and curves surfaces. This is just an egg..
This gives you much less room for a proper waveguide, which shows in the measurements.
The electronics actually look pretty decent. Looks like gainclone in there.
These things are just distort to much at any decent level to be anything other than a casual listening device.
For the money though, just get a second hand Genelec 8010 or 8020. Distortion wise the 8010 is quite a bit better even:
thewas
Thanks to the small size and known "Finnish" design it shows quite a nice directivity, so with a bit of free PC EQ a decent good looking small low budget desktop solution with only direct competitor the also 3" IK Multimedia iLoud Micro Monitor, we shouldn't forget that a Genelec 8010 costs more than double.
YSC
ignoring the direct copyish styling with waveguide, material etc. it really just tells how much knowledge Genelec have done to it's basic design. able to keep the 8010-8050 all analogue line performing so good, while someone copies most of it's design can't remotely do it as decent
Mnyb
Sweden, Västerås
For IP theft I don’t think the exterior shape is the main thing .
The square box is used by many ? And not considered ip theft .
If you want a well rounded enclosure with integrated wave guide cast in two halves in aluminium. You will have a really hard time not ending up with something looking like Genelec :) just as nailing together sheets of MDF at 90 degrees will look like a box.
But then they take more steps to make it even more Genelec like such as the mesh before the midbass driver and elastic foot and other small clues that looks distinctly Genelec.
But the performance seems riddled with easily avoided problems? They spent more time mimicking Genelec than developing the speakers, hence very poor
Vict0r
The Netherlands
098765
It reminds me of the speaker called "zenelec" made by canston.
Alex-D
I think the manufacturer have managed to uglify these speakers enough so that no one would confuse these with Genelec
manisandher
Royal Leamington Spa, UK
This is a review, detail review and listening tests of the Swan Hivi X3 active monitor. It was kindly sent to me by a member and costs US $249 for a pair.
I paid just a tad more for a pair of JBL 305P actives, which measure well and sound really good. (Not ideal for a desktop though - a bit large and too much hiss on idle.)
Rather than these Swans, I'd pay more and get a pair of 'real' Genelec 8010 actives, which are suberb (especially with a sub).
Mani.
Maiky76
French, living in China
As you see, this looks like a baby Genelec speaker down to the "Iso stand" and cast metal case. The former doesn't have a guide though so you can tell from the picture, you can wind up with it tilted left or right. I like the power switch on the side and volume control. Back panel also provides some tweaking of the response but it is limited to just 1 dB:
The port doesn't have clearance to go straight in so it almost immediate twists to the right and down into the enclosure. Overall the build is very solid making you easily confuse it with a top monitor brand.
Likewise listening tests comply with the latest research into proper evaluation of speakers calling for mono, instead of stereo listening:.
Reference axis is approximately the center of the tweeter.
Swan Hivi X3 Measurements
Let's start with our usual dashboard:
Well, this is kind of disappointing. We have a lot of disturbance in the usual port region of 800 to 1.5 kHz. Then we have three distinct resonances lifting lower treble region with the latter being quite broad. This will make the speaker sound bright. A look at the near-field measurement of the radiating surfaces shows some of the problems:
I don't think I have seen a port/enclosure with so many resonances. Maybe the inside is empty. On top of that we have a woofer resonance and lack of baffle step compensation. Not pretty.
General directivity is good which then causes off-axis to be as bad as on-axis:
Making our predicted-in-room response rough and tilted up:
Despite the built-in waveguide for the tweeter, response proportionally gets narrower with frequency (beaming):
Vertical axis though is above average due to use of small drivers with close acoustic centers:
I had high hopes that distortion would be kept in check but I could here severe distortion during measurement sweep:
There is some kind of limiter in there though allowing me to even sweep at 96 dBSPL which is nice.
Waterfall display shows resonances with strong ringing in time domain:
Swan Hivi X3 Listening Tests and Equalization
This is a tough speaker to love. Out of the box it is bright and you have to keep messing with the volume to keep distortion at bay. I tried filtering it but overall, I am not sure I made much progress other than making it less bright:
I like EQ attempts to be quick and simple by eye and this definitely not one of those cases. The highs can still be piercing even though I tried to bring resonances down. A fancier EQ may help more but it was beyond the scope and patience I had.
Mind though, there were moments of good sound at low volume but there far more annoying ones to my ear.
A speaker this small presents may challenges to the designer. I think it requires superb engineering to master all of that and that simply is not there. Is it good enough for a "3 inch woofer and 0.8 inch tweeter?" I don't know. What I do know that its capability is below what I consider good enough. So I would step up to next larger size and get a much better monitor.
I can't recommend the Swan Hivi X3 even though I see a reasonable attempt to create something unique and above junk plastic computer speakers.
As always, questions, comments, recommendations, etc. are welcome. Any donations are much appreciated using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Hi,
Here is my take on the EQ.
Please report your findings, positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 3.4
With Sub: 6.4
Spinorama with no EQ:
  • Port
  • too big bump in the upper mid
  • Decent, just a few tweaks could make it a nice speaker (with a sub)
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated one EQ. The APO config file is attached.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 4.6
with sub: 7.6
Score EQ Score: 5.5
with sub: 8.5
Code:
Swan HIVI X3 APO EQ Score 96000Hz
July012022-173726
Preamp: -2.5 dB
Filter 1: ON PK Fc 218.09,    2.47,    2.30
Filter 2: ON PK Fc 1281.48,    1.60,    1.40
Filter 3: ON PK Fc 2030.31,    -1.43,    2.58
Filter 4: ON PK Fc 3944.93,    -3.31,    2.22
Filter 5: ON PK Fc 6913.64,    -1.67,    1.80
Filter 6: ON PK Fc 18222.95,    1.40,    1.63
Spinorama EQ Amirm
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Nice improvements
The rest of the plots is attached.
  • Swan HIVI X3 APO EQ Score 96000Hz.txt
Chilli
Hamilton, NZ
Hivi are a great manufacturer. And I like them. Some of their drivers and tweeters have been the best or best value of their time.
Many DIYers have used their products and they have measured and sounded well. Some examples are some of the best measuring of their time. Some, not as good.
These X series started around 2010 to 2011. Thats over a decade. What the hell do you guys expect?
Some of the genelecs are some of the best in the world. It's quite clear these X series are a cute little monitor, but they're a desktop fad, in comparison to Genelec professional monitors. However, not all genelecs have measured perfectly, but some have measured extremely well.
Lets not judge a company, nor all Chinese speakers manufacturers, by one inexpensive little example please. I am interested in science. And science needs to be impartial and unbiased. You need context and you need understanding. Stick your veiled-generalisations to the side, and start your critical thinking.
They've designed speakers that won CES awards in the US in the mid-2000s, and they created an anechoic chamber somewhere in the mid-2000s. We wish them to do better, and they may already have done.
We will likely see more of their products being measured if people sent them in for independent testing. Let's hope their newer products do a better job. They're released with measurements and plots, so it would be interesting to see whether they match up.
I'm glad to see this speaker measured.
I don't think this speaker looks like the genelec at all. It's egg shaped and was marketed that way. The stand, well that could be suspicious as they were released probably in similar times. Genelec has had a decade to do something if they wanted but I seriously don't think it's worth it for the stand.
I don't think hivi and genelec are really in the same marketplace. I like Genelec as well. Wish I could afford.
DSJR
Suffolk Coastal, UK
I wonder what blocking the ports up (foam or similar) does to the upper midrange performance? No way can a tiny box do any bass so why try to make it when it patently can't? What's left may be tunable with a simple bottom to top 'tone tilt' as Quad preamps had?
Arc Acoustics
Japan
"No directivity control", seriously??
A tiny 3-inch (conventionally radiating) woofer and the small form factor inevitably result in low directivity even at 3 kHz, and we generally want decent beam width at the upper end, so the only way to get smooth transition is tilted directivity between the crossover and 20kHz.
The designer clearly intended to "control" and achieved it.
Actually, the cleanness of the horizontal directivity is pretty close or even better than 8010, with same-ish decent dispersion at 20kHz.
Of course, they would sound awful, the On-axis response is disastrous, distortion is unbearable, and port leakage is nasty, but the last two are the drawback of the cheap price and small form factor, and I insist there are "some" respectable engineering (or copy of respectable engineering).
Billy Budapest
My *guess* is that this speaker is not one of Frank Hale’s creations.
Swans/HiVi is a strange beast—a merger of a huge Chinese speaker driver manufacturer (HiVi) and a small American speaker manufacturer (Swans).
sarumbear
Score EQ Score: 5.5
with sub: 8.5
Why is everyone complaining about these little cute distortion generators? :)
With EQ you should get a speaker that people will prefer as much as Revel Concerta2 M16 or Performa M22, add a sub and it will fly around the Genelec 8361B in circles :facepalm:
