LaLaLard
I would like to know what is the scientific reason behind the "attractiveness" of tubey sound.
My impression is as below:
FREQUENCY RESPONSE
1. Tubes boosts mid-low frequencies which makes vocal more forward-sounding;
2. Rolls off high frequency and reduces low bass, which makes low-mid-range even more forward-sounding;
3. The reduced high frequency usually compensates for bad room-acounstic, especially rooms with too much reflection, which is where 90% of "audiophiles" listen to their system;
4. The reduced low bass reduces the significance of room mode.
DISTORTION
1. Some tube amps introduce more even harmonic Distortion compared to solid states;
2. This makes bass and mid-low frequencies sound "thicker" and more immersive;
3. More even harmonics adds that "metallic" colour to instruments and female voice which some people prefer.
Decay
1. Some tube amps got longer decay, which compensates for weak bass some times;
2. Which also makes studio-recorded vocal sound less "dry" sometimes.
CLIPPING
1. Old tube amps tend to have higher distortion than modern tube amps;
2. Back in the time it was rare to see amps with more than 20Wpc of output therefore most of amps would go into clipping when playing music;
3. Tubes sounds much more tolerable when going into clipping compared to early solid states;
4. People then believed tubes sound better;
5. Also the same reason that why some people claim "high powered/expensive SS sound more like tube". Is it simply due to the fact that they clip less frequently?
I concluded the above on myself after years of observation and discussion with my friends, some of them got technical background but most of them don't.
Please let me know what I've concluded wrong or what else would you like to add on!
FREQUENCY RESPONSE
DISTORTION
Decay
CLIPPING
