THD has a much bigger effect on sound than you think
Pdxwayne
DISTORT app doesn't do anything at 0dBFS -- it's up to the user to decide what signal to feed it as input and at what level. Internally, all computations are in 64-bit floating point, and any results that exceed 0dBFS are reported as clipping.
BTW, based on the graph below, what distortion numbers would you enter, when adding to a pure 0db tone in your app?
pkane
North-East
None. That measurement doesn't describe the transfer function in any detail, so it can't be reproduced from this plot.
Pdxwayne
Any useful info at all from the link to give you good clues?
Killingbeans
Bjerringbro, Denmark.
You claimed "everyone" can hear it.
What if I am one in a 100000 that could hear it and 99999 out of 100000 can't hear it?
If you push a man out of a moving plane, will you conclude that his death was "accidental" because the next 99999 people you push will have a chance to survive? I think it's fair to claim that "everyone" will die if you push them out of a moving plane :D
Same thing here. What we know about the nature of tones and masking is enough to disregard the minuscule "risk" of your experience being a fluke.
Pdxwayne
Words.....
I need actions. So far I see none would step up to provide abx.
Jimbob54
Thanks for the details explanations.
Hmm, talking about audibility.....
I played around with the distort app and able to get just 5th harmonic of 0.1% (-60db) added to 250hz pure tone.
Here is the deltawave spectrum comparison. As you can see, the second file got that 0.1% 5th harmonics.
I tried to ABX pure tone vs file with that 5th harmonic. Very difficult, but still able to get 8/8.
Post the 2 test files please.
pkane
North-East
Read up on the transfer function. Don't know how many times I have to repeat it. Don't keep asking me to teach you.
Killingbeans
Words.....
It's finally dawning on me that you're joking. That's fine and all, but maybe we should just move on?
There's a risk that other users won't be able to read between the lines and will draw all kinds of bonkers conclusions from your writings.
Jimbob54
Alas, I think not.
Pdxwayne
Should I assume you are talking about using 1 watts and 2 watts info to formulate a number that can calculate 5 watts, 10 watts, etc?
That one is straight forward.
But my main question is which watts distortion to use? Do you use 2 watts? Do you use 10 watts? If you are to simulate an amp in my example, which watt distortions numbers do you take?
Pdxwayne
No not joking. When I made statements in my other threads, many would ask me to do actual blind tests, do abx, etc. So, fair game I do the same to someone who made an "everyone can hear" statement.
Pdxwayne
Read them from the spectrum below and it will be quite representative. This amp is useless above some 7W.
Thanks! Yes, but still 5 watts. So, is this a good enough value to use when trying to enter distortion in pkane's app? Or should I estimate for 7 watts and enter those distortion numbers?
Related question: For other amps that can do much higher wattages, what watts number do I use? Can't just use 5 watts, right?
pma
Prague
It is still good enough (7W makes 1.46 dB to 5W) however your sine input file must be close to 0dBFS to verify the distortion, with lower amplitude the distortion gets quickly decreased. This should be understood as elementary.
pkane
North-East
An amp doesn't do something different with regards to distortion at some specific "watt" value. It is the result of a single transfer function that defines its behavior at all input levels. I've said this already, at least a few times. If you refuse to try to learn on your own, I really can't help you.
pma
Prague
Lost case. Many people spent hours or tens of hours of useless debates rather than 10 minutes of study. Such is life and the mix on the forum.
Pdxwayne
At least point me to a few good sites for learning please?
Pdxwayne
Well, you can also spend 1 minute to point me to good study links?
