The Hola is too dark for me and it has limited treble.
LewisGarcia
7hz zero and ZVX are really good value for money, There are too many killers for $20 right now. Waner is also good, I think I would recommend the above three to people who like warm sounds like me
fpitas
Northern Virginia, USA
Hola will do nothing of you kind. You might get used to it and like it, but that's something happening in you.
Maybe watering it will help? That makes plants open up :D
mc.god
Roma, IT
If it will not open up itself, you can always open it up yourserlf
Keith_W
Melbourne, Australia
The frequency response of IEM's is VERY seal and eartip dependent. I suggest you go through the different tips that came with your IEM's and see if it sounds better with another eartip. My ear canals are slightly asymmetrical so I need different eartips for my left and right ears, and even then I still get channel imbalance. EQ and balance control solves that problem.
GaryH
No surprise you don't really like the Hola (Harman predicted preference rating of just 65%), and find it dark with limited treble (negative slope value of -0.93), as that's exactly how it measures, incidentally similarly to the Truthear Zero Red with bass adapter (and without as well in the treble):
I too find frequency responses with this significant lack of ear gain dark, dull, muffled and lifeless, according with their predicted ratings from our current best science.
