ehabheikal
- Joined
- May 22, 2020
- Messages
- 442
- Likes
- 161
I do not know if this will be seen by anyone at these companies, but here goes. SMSL and other Chinese dacs that use the same remote are being used by some or many as preamps. The remote has one problem when used as preamp, it has no input buttons. Yes it has a change input button but that is severely limiting, not only is changing sources hard, you can not use automation and universal remotes that assume you can change to a particular input. This should be very easy to do even if they do not change the remote, they can just put in the firmware remote codes and publish them especially to harmony. That way all our usual tools to control preamps can be used.
