Topping D70S fried my speakers...
BR52
Germany
Good for you, but @Roland68 is talking about a very specific solution implemented in the product that reportedly failed. Take time to read his earlier posts here, highly informative.
A faulty drive-by-wire system would be a better analogy imho. And these do fail, don't they? Hence redundancy in airplane controls for example. And roughly the same dilemma: whether you want to trust a vital control entirely to software, which will never be 100% error-free.
I had a scare like this (no gear damaged tho) with a DragonFly Red fed from a smartphone. Since then, I avoid 100% digitally controlled volume with high power sources.
I guess you drive a car with manual gear box and hopfully the throttle is mechanically as well.;) A small chip called watchdog can improve the system (DAC) much to avoid controller hanging for example.............
BR52
Germany
I also had quite a bit of noise with my Heresy volume pot but I opened it up and sprayed cleaner into it and twisted it back a forth a bit. It's been perfect ever since. I wasn't sure if there was really an opening that would allow the cleaner to enter the pot, but apparently there was.
Please inform us how long the procedure will last.
droid2000
gadzooks!
Pricing starts at $540 for a simple volume control with no remote :oops:
Moderate Dionysianism
Spot on! It's a 2005 Mazda 3. Manual, mechanical and I do like the feel of it:)
I'd be happy to read more about those watchdog chips. Do you know of any DACs that use them? Such feature would surely go on my checklist when shopping for gear in the future.
Apesbrain
East Coast, USA
Very nice product. The price is similar to the DAC!!!! No remote.
You don't use it as a "simple volume control" and there is no need for a remote. Think of it as a "limiter": you set your DAC to 100% volume and use the Goldpoint (or equivalent) to set the loudest level you would ever listen. Your DAC continues to control volume, and if it ever resets to full volume the limiter keeps it from scorching your drivers.
Can't do much about the price, unfortunately, but there are less expensive options out there:
droid2000
Can't do much about the price, unfortunately. I'm sure there are less expensive knock-offs out there:
Oh, I see what you are saying...
One of these might work as well for a lot less money. Probably won't match the exact max volume you desire, but at least would prevent you from blowing out your speakers.
BR52
Germany
There are plenty in the market and very common in microcontroller designs in industrial applications. They have to be triggered by the controller periodically and if the controller hangs they perform a reset. This can be done every few milliseconds. Some also supervise the DC voltages in the system and so on.......
It's really not our job (customers) to check something like this because the product has to be well-designed!!
sibi1865
I used the Bel Canto Design DAC3 for a long time, around ten years. I'm now beginning to feel I should go back to it, or their pre-amp, on reading this thread because I had no such problems discussed here. It starts up in "soft mute" mode, and pauses at a certain volume level before ramping up more slowly thereafter. Their pre-amp available around the same time, the PRe2/P, had similar features. I'm now using the Benchmark HPA4 and the same safety features are not there. No accidents, but I've had some frights, and I'm now having to be a lot more careful, noting the volume setting that is not even displayed clearly on start up.
BR52
Germany
You can ask @John_Siau from Bechmark he is here in the forum and can give you more clarity. I guess with the HPA4 the problem is not existing.
Roland68
Cologne, Germany
When you buy a car that claims to have air conditioning, you do not expect a bug by which it spits out only cold air in the winter, and you get sick. And you don't want a process to activate air conditioning since it can be dangerous.
Your way of thinking does not make sense to me. You are paying for a product that is supposed to have some features and you expect them to work flawlessly from day one. What's wrong?
"The manufacturers should leave this function out of their devices (I mean exclusively the volume reduction in the DAC chip) or inform the buyer in detail and explicitly about the dangers of this function."
Excuse me, but didn't you read it, or what exactly do you find wrong with my opinion?
BR52
Germany
They "only" have to do it right thats all.
amarsicola
amarsicola
Rome, Italy
As i proposed im my first post, a good manufacturer would find the bug and relase a new firmware, i'm not even claiming the money i spent to recover my speakers. I don't see why dsp volume control would be inherently flawed or why a customer should ask to activate it at his own risk as you propose.
The precautions in Bel Canto firmware are not rocket science.
Manufacturers should just put more effort in engineering, that's why we pay our money. Or at least pretend that they are working on it.
The Topping guy is very active in this forum, not on this thread.
Sokel
There's a lot of ways to protect a device against such.
Problem is that most of this (hardware) solutions add to cost (sometimes a lot,a good pot is no cheap) and most importantly give a hit to SINAD and other specs.
The hit most of the times is WAY inaudible but if your way as a company is oriented to hit high SINAD no matter what I guess is a choice.
The honest think to do is inform people and let them take the risk if they want to.But I don't see such warnings often that's why we see so many surprised friends here,that's why we see threads like this often,so it's up to us as a community to do the dirty job :facepalm:.
Roland68
Cologne, Germany
The problem is and remains that the starting point in the DAC chip is always 0dB. That's hardwired and a fact.
If an error occurs, the part of the software that is supposed to prevent the registers of the DAC chip from being reset and thus being at 0dB is also deactivated or overridden.
Without additional hardware it would never be 100% safe in my opinion.
Do you know the scene in pulp fiction where the shot is fired in the car because of a pothole? The DAC chip is the weapon, the pothole is the trigger and the speaker...
This example describes very precisely the problem that arises when using this function.
BR52
Germany
This statement is a little misleading (wrong!). Because before the start-up initializing (writing to more than a dozen registers) the chip didn't know that it has to do. Multichannel, ....... Nothing. There is no hard wiring!! Not a fact in modern DAC's anymore.
Anyhow, it is the responsibility of the developer to make sure the system is not harm outside components with an appropriate circuit, SW. This is possible.
For the user in some DAC (appliance) it can be default, but this is Firmware.
Here is an example for a chip:
  • ES9028PRO_Datasheet_v3.6.pdf
Music1969
A good reminder to turn on speaker power amp last - at least then you can see the DAC's volume before you turn on speaker amp last.
As a safety check.
This way the risk with connecting DAC direct to power amp is greatly reduced.
And when powering down the system, turn the power amp off first.
Sokel
Sorry if I missed it but where there any attempt to reach the manufacturer about this?
And if so,what was their response?
