Topping D90 Balanced USB DAC Review
win
Irvine CA
This review pushed me over the edge to upgrade my current dac (jds labs el dacii) beacuse I wanted a balanced output one anyway.
See you in a decade when any further advancements to DACs beyond this D90 are relevant to humans :eek:
Cut-Throat
What is that thing above the D90? And what equipment rack/holder is that? Looks real cool...
I had an Acrylic shelf made. And atop the shelf is an Allo Digione (Which is a Raspberry Pi with a Digitial Output Board) - A Network Music Streamer. It is my only Audio Source. Any Radio Station in the world as well as Spotify and Qobuz and my 5,500 Album Music Library.
jtwrace
Orlando, FL
AbsolutelyDACs works well for streamers. I'd go so far as to say it was made for them!
Not all dacs work with streamers, hence the question.
wemist01
Chicagoland
Yes, Topping has supplied the PDF to "printer spreads" for a single sheet of paper that gets folded up in the product box. The PDF document is unwieldy since some pages are sideways. But Acrobat's interface is highly capable. If a PDF presents a challenge, the tool you need is likely there.
First, make sure you recognize the difference between accessing and reading PDF files in your web browser using the Adobe Acrobat plugin and downloading the file and opening it in the Acrobat Reader application. You may or may not be loading the PDFs into your browser. If you are, back up, right-click on the link to the file and choose "Save link as..". Your file-reading options are going to be far more robust using the Acrobat Reader application.
Zoom and rotate options are available under the View menu, and both will have keyboard shortcuts. If you make your tool choice the hand, you can freely move the page around, zoom in and out, rotate right and left, all very quickly. You just need to mentally note the shortcuts. You probably have the same shortcuts I do:
Zoom In: Control + Plus
Zoom Out: Control + Minus
Rotate Clockwise: Shift + Control +Plus
Rotate Counterclockwise: Shift + Control +Minus
Cut-Throat
Well, let's say any Streamer that I would be interested in will have Digital Outputs. In fact I am not aware of a streamer that does not have a Digital Output.
jtwrace
Orlando, FL
You're missing the point...it's not about the streamer having a digital output. It's about the DAC being able to work with the streamer on an OS level and that being fully Linux supported.
dmac6419
USofA
Yes, I have "Allow applications to take exclusive control of this device":
The Tidal Settings in the File Menu takes you to the settings dialog:
^^^ then click the Streaming Tab to select the Sound Output device for exclusive use,
and then click (More Settings) to get into this dialog:
When I toggle the Tidal "Use Exclusive Mode" option in the Tidal Streaming settings dialog the FiiO M15 USB DAC mode display changes from 384k/32bit to indicate the change, in this case to 88.2khz/32bit, and if I toggle the "Use Exclusive Mode" off while the Master Track is playing the FiiO M15 USB DAC mode display changes back to 384k/32bit.
And, here is the youtube playback error when Tidal has Exclusive Mode use:
Immediately as I disable "Exclusive Mode" toggle in Tidal I can refresh that youtube page and it will begin playing with audio.
I'll report back when I hook up the D90 MQA and see if that works the same.
Probably related to Fiio M15
Cut-Throat
Yes, Pardon me I am completely missing your point. I am not aware of any Streamer that has a Digital Output that a DAC could Not handle. Can you link to one, so I know what you're talking about.
hmscott
Thanks for reminding me to check this on my D90 MQA :)
It took just a minute to verify the same thing happens with the D90 MQA.
The D90 MQA is acting the same as the FiiO M15 with regards to this "Exclusive Mode" Tidal App behavior.
I can switch mid-stream from MQA to PCM and back by dropping out of Exclusive Mode (flipped the Stream settings option) and switching it back on again.
When I have Tidal App running on Windows 10, enable Exclusive mode - the D90 MQA shows "192khz / MQA." and trying to run another audio application fails - youtube for example shows a renderer failure, same as on the M15 as the USB DAC.
And the same as with the M15 the D90 MQA switches from "192khz / MQA." to "384hkz / PCM" as soon as I switch out of Exclusive mode in Tidal App, and I can refresh the tab running that youtube video and it plays fine.
Update to add Topping D90 MQA Tidal Settings dialog, Enable "Use Exclusive Mode" and "Passthrough MQA" for D90 MQA use:
IslandMD
Victoria, BC Canada
Which software are you running on the RPi?
Cut-Throat
Thanks. I'm using "Volumio Free" in my Odroid C2 streamer which works great as a DLNA renderer for JRiver/JRemote but unfortunately, to add Tidal or Qobuz support you need to subscribe to their MyVolumio service. I'd rather not add another subscription service.
I think you'll like PiCorePlayer. It is the most feature rich and supports more software than any streaming software I've come across. It is also free, but I donate to the Group of Developers. They are on the Squeezelite forums on a Daily Basis for Support.
I've tried Volumio at various times, and found it rather Buggy. I tried to use it last month under the free trial for 30 days and was unable to get QOBUZ Working at all. They did get back to me in a couple weeks and told me that they had fixed a bug in this area.
EchoChamber
Unfortunately Volumio's user experience is lacking... I had the subscription but using Tidal on the Volumio iOS app was far from the Tidal iOS App experience, I ended up streaming using AirPlay so I could use Tidal and Amazon HD native apps. I'm now trying Roon (not free) which is at a whole other level, they actually have product designers in their team. Running RoPieeeXL on my Pi 3 B+ works really well and has a ton of features using the Roon DSP filters.
auronthas
D90 works well with my streamer Auralic Aries Mini via USB and stream wirelessly to my NAS. D90 connect to both A90 headamp (RCA) and Krell integrated amp (XLR) respectively to headphone system and speaker system.
Awaiting another pair of XLR cable to bridge A90 (XLR out) to Krell (XLR in), D90 (XLR in) A90 (XLR out).
