concorde1
- Joined
- Mar 15, 2021
- Messages
- 366
- Likes
- 282
I've had a Topping D90 for at least a year. It always worked fine on my PC (Win10 and also worked on Linux).
I just built a new PC, also on Win10. I plugged D90 in to a front USB3 port. This port works - my external hard drive shows up through it.
I turned D90 on and installed the Topping 5.62.0 driver. Reset the D90. But in Topping Control Panel it says "No Devices Connected" - I can't find the device in Win10 Device Manager.
No sound. Also the sample rate is showing as blank on the D90 screen, unlike when it's working.
I also tried an older Topping driver with no success.
I've tried two USB cables (one is quite long maybe 3-5m but always worked; other is the one that came with the D90).
I've tried three different, functioning, USB ports.
I factory reset the D90.
The only sign of the D90 was under Hidden Devices in Device Manager, there was an Unknown USB Device, that said "Device Descriptor Request Failed". I "uninstalled" the device in Device Manager and restarted, and that didn't help, but now the D90 is turning itself off, about 30 seconds after turning it on.
Any ideas on how to get this working? Thanks
