Try https://www.tpdz.net/newsinfo/474829.htmlThe DX3 pro+ has just arrived at my place. Unfortunately, I cannot install the v5.20 driver on my Windows 7 system (*error message: Setup cannot run on the current operating system).
Is there another driver that works on a Windows 7 PC? Otherwise I have to send the DAC back again.
5 or 7Hi all, I recently ordered this dac/amp and I was wondering which of the filter settings would be the best choice? From the graphs and the ESS DAC datasheet I want to say either Filter #2 or #3 (default).
Thanks. Driver 5.0 worksLooks like V5.27 is the latest overall, V5.00 is the latest for Win7. Try both maybe.
I have the answer now, no need to respond to this.I would like to know if this chain will work:
PS5 > USB out to Signstek UAC1 Mini DAC > Signstek Toslink out to miniDSP 2x4 HD >miniDSP USB out to DX3 PRO+
Doing this to avoid using the dodgy S/PDIF system on the DX3 PRO+
Only reason to switch to high gain is if you want it louder than what you get maxin out at -0db on the volume.Hi all. I'm new here. I've just ordered a DX3pro+ to act as a simple headphone amp + dac combo in my office setup. Currently using it with Sundara's and I noticed that several of you are using the same combo. I was wondering what was the best gain setting for Sundara's (High or Low) ? Currently using low gain since unboxing and -36dB low gain seems confortable with the Sundaras.
NB : I also have a Loxjie D30 (2021 version) on hand and trying to A/B test the differences with the DX3pro+. Tough choice.
Yes, USB, from the back of PC.Ground loop? What input are you using, USB?
Than you should avoid fluxlabs ampsI just wanted to mention, how much I hate this knob.
This clacking when turning is terrible. A knob has to be smooth...
