Topping DX5 Review (DAC & HP Amp)
Rate this product:
    Votes: 16 4.3%
    Votes: 8 2.1%
    Votes: 89 23.7%
    Votes: 263 69.9%
Bleib
Sweden
Many thanks, I bought the product :)
Better price till 25th
HDavidson
Had arrived Topping DX5 Lite.
I can't figure out how to switch AMP - DAC - Pre positions.
On Remote control and without it, in case a dog ate it ))
The headphone amplifier is rather weak for 300-600 ohms. For Focal Clear the normal level is -20dB per +12dB gain control H.
Where and how can I check the firmware version?
Berwhale
If you have the ASIO drivers installed on Windows, it's in the Info tab, see 'revision'...
See manual for switching options...
You can't switch DAC (i.e. fixed output)/Pre-amp mode directly from the remote, it's only in the menu...
Personally, I don't see the point of the headphone amp + line output setting. I've trained an IR controlled mains socket to respond to button 4-8 on my Topping remote as it's only used for accepting menu options on my EX5 (it does nothing when not in the menus).
HDavidson
Fixed DAC output can be adjusted in the menu: switch on the back and simultaneously press the button on the front of the device.
Be careful not to plug in headphones in DAC mode. The volume is set to maximum and cannot be lowered.
Topping cannot give clear and understandable instructions for adjusting the apparatus ??? ((((
Trell
So by a simple click on a button (large one between input prev and next buttons) during play back you could accidentally output to headphones amp and lines out at the same time during normal usage? If true, that is a dumb user interface.
Berwhale
Agreed. Can someone with a DX5 check if the HP Amp volume or the full line out volume (or both) is honoured in this case.
HDavidson
Mode DAC accidentally pressed the button on the headphones and got hit on them, at full volume.
Interface very strange is not enough to say. Real gas plant.
Trell
Hopefully you did not damage your hearing!
It's not enough, for me at least, to have an excellent audio performance but then have so other real issues that are potentially dangerous in normal usage.
Atanasi
It's a PDF. So text, not image.
Man did you even download the thing?
The file seemed to be a vector rendering but without text tags. Text search didn’t work and Google Translate said ”Can’t translate scanned PDFs”.
staticV3
In that case, there are a number of image translate services that can be used:
HDavidson
I looked at the firmware version - 1.08. I looked on the official website Topping and didn't find it.
HDavidson
Quel est le numéro de version actuel du firmware pour DX5 et où puis-je le télécharger ?
PS
C’est pourquoi je ne l’ai pas trouvé. Lors de la traduction, le site donne ceci. :facepalm:
HDavidson
After the update (update process was successful) of the version of FW 1.38 DX5 downloaded from the official site Topping.
Error message: incorrect FW ver
Product blocked :facepalm::mad:
