Morpheus85
- Joined
- Mar 30, 2020
- Messages
- 111
- Likes
- 49
yesWith headphones?
yesWith headphones?
mine is made of plastic.They sell an aluminium remote:
This optional remote control is very good. It is heavy and has a luxurious feel. I bought two.They sell an aluminium remote:
Just tested it. There's absolutely no pop sound to be heard when using headphones from switching sampling frequency.
How to test it?
Set digital volume on PC or e30 to -50 or lower. Make sure there's still sound playing so you know the output is not turned off.
Then test replay, change sampling rate etc
If you don don't hear the pop anymore it means it's not the pop sound we all were referred to.
The pop you heard is the transient caused by cutting of audio signal. The edges in time domain has a lot of energy and high frequency content so you can hear it. It's an issue since like forever. The solution is simply fade in and fade out. It's in foobar, Spotify or majority of players. In ASIO mode foobar can't process the fade in fade out. Hence the pop.
This particular issue is not immune to any dac. The original actual pop is only audible directly connected to power amp. This issue is only not present on ESS dac or DACs with ASRC in the front.It may be an issue since forever, but my other DACs don't exhibit the behavior.
D10 with ESS chip does not suffer from this problem. It's an AKM issue that is difficult to resolve, especially in this price range (~$129)Incidentally, the topping d10 does not have this problem.
BTW does that mean that AKM chips have a different kind of ASRC, or none at all?This particular issue is not immune to any dac. The original actual pop is only audible directly connected to power amp. This issue is only not present on ESS dac or DACs with ASRC in the front.
AKM is not asynchronous. Thus it needs to change the internal logic for different sampling rate. Modulator will have noise as output during that period. The time is short hence it's only a pop. ESS has ASRC in the front hence changing sampling rate does not affect the operation of the dac. chips like 9038 can run in synchronous mode in which the issue should still be present.D10 with ESS chip does not suffer from this problem. It's an AKM issue that is difficult to resolve, especially in this price range (~$129)
I see, thanks for the explanationAKM is not asynchronous. Thus it needs to change the internal logic for different sampling rate. Modulator will have noise as output during that period. The time is short hence it's only a pop. ESS has ASRC in the front hence changing sampling rate does not affect the operation of the dac. chips like 9038 can run in synchronous mode in which the issue should still be present.
Whatever I do, there is never any sound out of the DAC unless I set SACD to output DSD+PCM. Then it appears to just be using PCM, as if I use one of the "DSD : ASOI/WASAPI" outputs then I get no sound again. The DAC panel always shows PCM, regardless.
It should be fine as you have volume control after E30.Considering buying the E30 and hooking it up to my S3000Pro. Should I be concerned regaring this pop issue???
Not recommended.
1, E30 won't break
2, You will suffer from frequency response change due to the high output impedance.
3, DT250 will be better but still not recommended.
You can just use what you have been used and wait for L30. Or try it out, you may like the change in frequency response who knows. The output opamp is not very powerful but it's still better than some of the diy amps happened a decade ago.
Just don't worry about it..Thanks for your response. Altho it stil not clear for me in what cases does this pop occur, could you elaborate on that please???
Excuse me,I received my E30 from Apos yesterday and I can confirm that DSD (including DSD64) works for me. It was a pain in the butt to set-up foobar, but it would have been much easier if I downloaded Topping's driver and instructions from the beginning. So far, I really like this little guy!
