Topping E30 II DAC Review
Rate this DAC:
    Votes: 14 4.3%
    Votes: 22 6.8%
  • 3. Fine (happy panther
    Votes: 103 31.7%
    Votes: 186 57.2%
This is review and detailed measurements of the Topping E30 II DAC. It was sent to me by the company and costs US $149.
The single "SEL" button powers on the unit (touch sensitive) and selects input. Some combination of power cycling and that button lets you change menu settings but bets to use the included remote:
There is no power supply included. There is a USB to 5 volt barrel connector giving you the choice of how you feed it. I started with my USB hub built into the monitor but got the best results with a Samsung USB charger. Your situation may vary as you don't have an analyzer in front of the unit.
Topping E30 II Measurements
This our dashboard using Toslink input:
And now USB:
Depending on grounding, I could almost get up to 118 dB SINAD. But going with what we have, performance is still excellent:
Here is our dynamic range:
And IMD test:
Jitter performance is very good with USB input:
But both Toslink and Coax showed significant 250 Hz jitter components:
As noted, these are inaudible though as the typical level is below threshold of hearing/masked.
Linearity shows a hair noise but otherwise is excellent:
Multitone test highlights the very low levels of distortion:
Here are the included filters:
Using the default F2, we get this wideband distortion+noise vs frequency:
Not state of the art but still very good.
Great to see my favorite "orange LED" DAC updated. Performance is improved across the board compared to Topping E30. Yet the price has hardly changed. We are talking about near state of the art performance in a finished DAC selling for just $149. With good looks to go with it.
I am a bit bothered by Toslink and Coax Jitter. AKM chip used here doesn't resample as ESS does so any issues there travel right through the DAC. Fortunately it is not an audible concern and for someone like me who uses USB as the primary input, non-issue.
I am going to put the Topping E30 II on my recommended list.
Zek
Also on L7 Audiolab site...
DSJR
Suffolk Coastal, UK
I'm sure this will be answered in due course, but what was wrong with the I to justify a II model so soon?
Series 1 at £134.10 on Amazon (10% off) so to me a bit of a bargain.
Sokel
The display is orange or red?Seems different in the L7 review.
JohnYang1997
China
Well yeah we are easily running into the constraints of digital to analog conversion.. have been for quite some time ;)
Thanks for the review @amirm! @JohnYang1997 any chance for info on the coax/optical receiving compatibility?
I'm pretty sure it's not going to be a problem this time. But I cannot say for 100%.
fordiebianco
British Isles
MajorP
@JohnYang1997 I bought an E30 DAC in 2021 (S/N starting with 2106). The unit is producing drop-outs from time to time when using toslink. Any chances Topping can exchange my unit to the new model?
Best regards
MajorP
Has it always been the case, or just recently? I don't think the E30 has a variable DPLL setting.
JSmith
This always has been the case. It does not occur all the time though.
I'd say round-about once a day.
Does not happen when I use a Fiio DAC instead.
The E30 is connected to the Toslink output of my mainboard (Realtek Digital Audio (S/PDIF).
