are anyone here loving their L30 MK2? I've been pairing it with my headphones for 2 days (dt990/hd650/...) but I don't find the sound as good as I hoped.
measuring good don't mean sounding good, there's a JDS atoms used to be very hyped
I paired it with my r70x. it sounds amazing and better than previous one( l30 mk1 ) in every aspect. I guess it wasn't enough to handle r70x with 6vrms power output. and now I got l30 mk2 which can provide 13vrms @300 ohm, I can clearly hear the difference in overall sound quallity.are anyone here loving their L30 MK2? I've been pairing it with my headphones for 2 days (dt990/hd650/...) but I don't find the sound as good as I hoped.
For me high gain sounded the best. Punchy bass, dynamic and sharper treble. I'm happy for it. Medium gain had clean lows and smooth upper frequencies. A bit lifeless but for evening listening could be better and easier to control volume. I think it's the distortion thing but I like it.measuring good don't mean sounding good, there's a JDS atoms used to be very hyped
Making stuff up as you go, are you?For me high gain sounded the best. Punchy bass, dynamic and sharper treble. I'm happy for it. Medium gain had clean lows and smooth upper frequencies. A bit lifeless but for evening listening could be better and easier to control volume. I think it's the distortion thing but I like it.
I got it as an cheap experiment and the more I am in this hobby the more I realize the full pairing along the full chain end up being rather important.are anyone here loving their L30 MK2? I've been pairing it with my headphones for 2 days (dt990/hd650/...) but I don't find the sound as good as I hoped.
I meanmeasuring good don't mean sounding good, there's a JDS atoms used to be very hyped
Obviously, you made a wrong turn and got lost....measuring good don't mean sounding good, there's a JDS atoms used to be very hyped
Obviously, you made a wrong turn and got lost....For me high gain sounded the best. Punchy bass, dynamic and sharper treble. I'm happy for it. Medium gain had clean lows and smooth upper frequencies...
feel free to criticize or discuss my impression, there's no way I did listen to it in a valid or scientific manner.
with beyer dt880 600 ohm it just sounded like the headphones can still use a bit more oomph. would be interesting if someone here also owns 600 ohm beyer cans and share his/her impression
You will need high gain (medium is unity gain!) but yes I don't see why it wouldn't work for your useHow useful would this be for a dedicated pre-amp? I've been looking for something with RCA in/out that can give me a 10-20db boost with as little noise or distortion as possible. I've mentioned in a couple other threads that I use the SVS Soundpath Tri-Band wireless for my rear-surrounds and I'm struggling to get an amplifier to power speakers to level match my fronts. Cranking any amp I have on hand to max volume seems to get the job done but the static noise is awful.
This looks to solve my problem; take a 1v low volume signal and pre-amp it into dedicated speaker amplifier so that I only need to crank it halfway instead of maxing it out. Would the high-gain on this device be a good purpose for that? Or medium gain with max volume?
For a budget of under $400, I am undecided between:I got it as an cheap experiment and the more I am in this hobby the more I realize the full pairing along the full chain end up being rather important.
And that's not only amp + headphone but source + DAC + amp + headphones + your ears!
What you don't like? Compared with what other setup?
What are your source and headphones?
do you mean DX3 Pro Plus?For a budget of under $400, I am undecided between:
1. DX3 Plus (because I probably would not hear the difference anyway) for ~200
2. DX3 Plus AND later add an L30 II (to have 16bits at 50mV - is this very important? Is it audible?) for ~350
3. E30 II + L30II (best parts given the budget) for ~280
What would you pick and why?
#3, because it has a lot more power. Especially at low impedances.What would you pick and why?
