raif71
- Joined
- Sep 7, 2019
- Messages
- 2,350
- Likes
- 2,566
@Kujo I have both stacks. My usage scenarios are iems will be using e30/l30 and headphones will be with the d50s/a50s. Of course either stack can be used for both iems and headphones but my Senns hd598c/hd600/6xx/660s and Sundara are wired with 4.4mm pentaconn so they will use the d50s/a50s. Most of my iems are SE so they can go with the e30/l30 and l30 has the -9db gain. If you're deciding to get one stack just weigh whether you'll be getting balanced wires or not. If not, the e30/l30 should be enough.
