Topping PA5 II running hot on idle
cptsantos
Hi guys,
I just bought a Topping PA5 II and have been testing it for the last 3 days. I’m surprised to find it runs very hot even on idle and even at zero knob volume. Weren’t this class D amplifiers supposed to be very energy efficient? The PA5 runs hotter on idle than my Sonos Connect Amp (ZP120) playing at high volume.
Is this normal? I’m thinking about sending it back just because I think at this temperature it will not last long. Is anyone also experiencing this?
kunkurus
I have the same problem when using PA5 II with Polk TSi200 Bookshelf (8 ohms). But it is only warm when using it with ELAC Uni-Fi UB5 (4 ohms).
natna
@cptsantos Where did you buy from?
@kunkurus from the things you write you seem to have a problem of hight temperature on idle with both Polk AND Elacs!?
Roland68
Cologne, Germany
Hi guys,
What exactly does “hot” mean?
Without specifying the temperature, it can be anything from 30° - 70°.
By the way, amplifiers require a basic temperature for a stable operating point.
kunkurus
With the Elacs I just measured 36 degrees Celsius at idle (23 degrees ambient temp). I have no measurement for the Polks, but I'm pretty sure it was more than 40.
cptsantos
cptsantos
Hot means very warm to the touch. It’s possible to touch it and keep your hand there but a few more degrees and it would be too hot to keep your hand.
Roland68
Cologne, Germany
Unfortunately, this is also far too imprecise, as everyone has a different perception of heat. But based on what you said, I would assume 30° - 40°, which would be normal.
You don't need to worry about the service life at such temperatures.
Bleib
Sweden
A few rules I have with my PA5 II Plus
1. Don't stack units on top of each other, no DAC underneath it either
2. Raise the unit a bit so cool air an come underneath the unit
Roland68
Cologne, Germany
It always makes sense to not place any device on top of an amplifier, but there is no problem with the original feet underneath.
The air circulates thanks to the heat anyway and thereby cools the device. The warmer the device gets, the more air circulates.
But it doesn't hurt to lift your feet either.
DTTOM37
French side of Europe
Using a PA5 II (bought from Audiophonics) in an active system driving one Tangband WB-1772 (8 Ohm - FR 250hz-20khz) per channel at full power output, volume regulated from the DAC , usually - 25 dB, until now the amp runs cold to the touch.
Roland68
Cologne, Germany
And that is exactly the problem.
Without specifying the exact temperature, we are moving in a range of at least +/-10°, or more.
If you push two people into 30° water, one of us will say "that's pleasant" and the other will say "that's cold".
Then there is the experience with other devices. Most A/B amplifiers are in a temperature range of 35°-55°, class A even at 60-70°. Based on this, a PA5(II) will feel rather cool. But someone without that experience might find that hot.
cptsantos
cptsantos
Thanks.
That’s similar to my setup. WiiM Pro Plus > PA II > Wharfedale Diamond 220s 8ohm. Volume controller by the WiiM.
cptsantos
cptsantos
A little common sense please.
@DTTOM37 said “cold to the touch”.
I don’t need to measure the exact temperature in degrees to know that my PA5 II is definitely not “cold to the touch”.
I’m also pretty sure @DTTOM37 or any other person wouldn’t consider it “cold to the touch” if he/she touched it.
Roland68
Cologne, Germany
Exactly, because then no PA5(II) can feel cold, at least not at normal room temperature.
The only exception would be a defective device.
A large part of the heat when a PA5(II) is switched on and unused is generated by the voltage regulators, which have to bring the 36v to 12v. Therefore, each of these devices must noticeably warm up as soon as it is switched on. This is simple physics.
natna
Mine came on Monday from France.
It sounds very nice...
I did left the amp powered on idle. I'd say it stays lukewarm.
With 21 C degrees in the room, when switched on, the shell has the room's temp and feels a bit cold to the touch.
After 30min and up to 6 hours later, it's only lukewam to touch.
I don't have an infrared temp gun to measure it, but surely is no hot.
