Topping PA7 Plus Amplifier Review
Rate this stereo amplifier:
    Votes: 15 4.0%
    Votes: 38 10.1%
    Votes: 149 39.5%
    Votes: 175 46.4%
I’ve just hooked up a second PA-7 Plus, 1st in a horizontal biamp config, then today in a vertical config, to a pr. of Musician Knight 1’s. I purchased a second amp after remembering how a fella with Falcon Acoustics, who was previously w/ProAc, had highly recommended biamping the 1SC, of which I own. The single PA-7 was put to use with the Knight 1’s, a really well built 2way, cause that’s what’s in rotation. Very nice on its own, I was a bit startled by the improvement in the horizontal config. Damn, quite a bit more, there there. Increased vocal clarity, density and ummmppphhh as I listened to Dope Lemons newly released Miami all the way thru. I certainly wasn’t missing those little gold bar jumpers between the binding post. Stacked PA-7s seem just fine. Tiny stack that is. One silver, one black, cause that’s what they had and I got each for about $460. Today after knuckle heading around ‘cause I’m using two different speaker wires, I went ahead with a vertical e config. Amos Lee’s Chet Baker songbook is sounding dead quiet, focused and sublime. Very nice ease and flow, effortless. The Musician speakers are just eating up the additional pow. Not a 5-10% improvement, more like 20-25%. The Knight 1s are a beautifully voiced pair of speakers, tonally dense but airy beasties. Feed em well. The little ProAcs are sitting aside for now, waiting for me to remove their silver jumper wires, but that’ll wait. I was a bit hesitant purchasing a second PA-7 Plus almost on a lark, but it really is the way to go if your speakers are designed for such. Oh, both are being fed by the new SMSL PL-200 cd players outputs. Between the PA-7 dip switches and the SMSL menus I’m still sorting things thru, but this config is making a major case for biamping as the way to go. Highly recommended…
Biamping with the crossovers after the power amps (they are still present inside the speakers) does little.
With the gold bars present and a single PA7, the tweeters see half of one channel of the PA7, and the woofers see the other half.
With the gold bars removed and two PA7s, the tweeters see half of one channel a PA7 and the bass frequencies are turned to heat, and the woofers see half of one channel of the other PA7, and the treble frequencies are turned to heat.
Both amps are still producing the entire tonal range, including cross talk, and half of it is being turned to heat inside the speakers.
Horizontal or vertical makes no difference.
It would be more useful to leave the gold bars in place and use more powerful amps, for example by using the PA7s in bridged mode, and use one for the left and one for the right. Before rushing to do that, I have not seen that the PA7s are bridgeable.
Where bi-amping becomes truly useful is to remove the gold bars and to put crossovers before the amps. Crossovers before the power amps can be as simple as passive capacitor/inductor/resistor circuits; can be an active circuit; or can be a DSP such as a miniDSP.
By doing this, you can avoid the bass amp wasting effort on the treble frequencies, and can avoid the treble amp wasting effort on the bass frequencies.
The purist would also insist on disconnecting the crossovers inside the speakers. You may wish to leave a capacitor in series with the tweeter for protection.
Using e.g. a miniDSP, you can then connect the speaker drivers directly to the power amp, and use e.g. REW software to dial in a perfectly flat (or any other shape) speaker response to eliminate room modes or resonances. This would also eliminate any wasted power in the crossovers after the power amp.
The cheapest route for this might be a miniDSP 2x4 HD, a UMIK-1 mic, and the free REW software.
A more automated solution is the miniDSP DDRC-24, which is the 2x4 HD upgraded with internal Dirac software, plus an included UMIK-1.
A "nicer" route might be the miniDSP Flex, UMIK-1, and REW
The miniDSP Flex can also be upgraded with Dirac software.
excuse me if someone gets upset ... but, after PA5 1 fiasco and that ocassional "glitches" in new PA5 / PA7 ... people continue buying these amplifiers?
hypex solutions with really higher reliability are a few dollars more, i can't understand it
I cannot find a Hypex solution delivered to US for only "a few dollars more" than a Topping solution delivered to US.
Topping US distributor APOS Audio has the PA7 at $449, already in US, with 2 year warranty.
Cheapest Hypex NC502MP I can see is the Buckeye at $695 with 1 year warranty. Much larger, too.
A different question is why do people buy either the Topping or the Hypex when the Fosi V3 exists? It was $87 with 48v PSU in December.
mike70
150 usd buys peace of mind for me, totally.
Fosi V3 doesn't have PFFB, one of the reasons in their lower price tag
Repdetect
Just to clarify- Isn't PFFB really only of benefit with 8 ohm speakers?
mike70
Does PA7/PA&+ use PFFB?
pa7 / pa7+ doesn't show load dependency ... it isn't clear to me if they do it with a PFFB circuit or with a propietary solution (potted circuits)
the question is that load independency have a cost, and Fosi (at this moment) decided for a cheaper product ... that's why i don't add the V3 in the same league as topping / hypex.
Is like claiming why an off-road vehicle is more expensive ... we can't compare bananas and potatoes.
NTK
US East
Most likely it does. Here is the PA7's FR plots into 4 and 8 ohm loads.
Here is the plot for the 3e Audio with PFFB.
And here is the plot for the Fosi V3, which does not have PFFB and showed load dependence within the audible band.
Guddu
I was genuinely asking as I didn’t find the info about PA7 PFFB.
Not keeping other TPA3255 in same league as PA7, I know it’s not because I own A07, A07 Pro, A07 Max, ZA3 along with PA7..
Guddu
Thanks, but if it does then why would Topping not advertise it, it’s only add up to a selling point for them.
mike70
it's ok, that part wasn't a direct answer to you ... is relative to price tag / features in general that other users mentioned. PFFB IS more expensive.
Vladetz
Russia
Some reasons for me personally:
- Hypex is not available in my location
- Shenzhenaudio returned me full cost of defective pa5 and shipping
- all my other topping products were flawless, including pa7
- on sales you can get it much cheaper - about 350$
Guddu
What makes PFFB implementation expensive, from PCB/components prospective?
Anyone who could tell.
@daniboun
@Toku
MAB
Portland, OR, USA
You should read up on bi-amping.
Specifically passive bi-amping. It has no effect on the sound.
It does not reduce IMD in a measurable way as some have proposed.
If you have listened to the two configurations level-matched and blind, you would not be able to tell the difference. Unless an amp was malfunctioning. And passive bi-amping doesn't even give more headroom. If you need more power or SPL, get a bigger amp. Or more efficient / better speakers.
Those bi-wire terminals on speakers are there to sell you things you don't need, like extra wires, or in your case a redundant second amp.
mike70
If a defective amp burn your tweeters / crossovers ... that have not refund. And depending on your speakers price tag, the fix will cost many pa5s :)
daniboun
France (Lyon)
Just in case anyone was interested, I asked Topping customer support about this, and the answer is: yes.
This is native for all TPA325X chips )
Reactions: MAB
Iluzun
Bullshit, u know not of what u speak…. If the internal crossovers are designed properly, inductors and drivers designed to deliver, you r dead wrong and parroting what is a common misnomer, a fallacy. I’ve spent 3 days sorting, ordering, and rearranging a well sorted setup. Even a horizontal config is readily noticeable. The verticle simply stomps! I’ve rotated thru 2 pre configs, a Denafrips Athena w/dual balanced and single rca output and Benchmark 3 Dac preamp w/dual rca output & single balanced output. Done properly, if you can’t easily differentiate, get another hobby, you r deaf. The spatial legibility, separation, clarity and drive are unmistakable. It’s simply far superior.
Toku
Japan
@daniboun
@Toku
For a long time, many companies could not adopt PFFB due to patent barriers. The patent has now expired and anyone can use it.
PFFB itself is not technically difficult and can be realized at low cost by adding a few parts.
However, along with the adoption of PFFB, manufacturers are upgrading their products to even better products by adopting high-quality inductors in the output filters in order to make products with better characteristics and more attractive features. That's why the price is a little high.
PFFB amplifiers such as Topping, 3e audio, and JLE are such products. I'm all for using quality parts, even if they are a little more expensive.
Iluzun
Just to kick a hornets nest. If I had to live with the horizontal config, I still prefer the tweets run w/a quality tube amp vs the second PA-7. There’s a liquid dimensional depth & sweetness you don’t get horizontally w/a 2nd PA-7. It’s flatter and not as emotionally involving, drier. Vertically the 2 PA-7s come out superior, everything just comes together. The verbal content of lines become legible in a way a single amp can’t discern. Tones and textures have additional body becoming more palpable, impactful. These benefits are quite easily heard. Musician Knight 1’s weigh 34lbs each and substantially benefit from being run in a verticals biamp configuration. Oh, so do the ProAc 1sc, a legendary monitor, w/their rhodium speaker connects & copper phase plug. Both two-ways internal crossovers provide a substantial upgrade that can be explored with these new affordable amps. Blanket statements regarding active vs passive speakers are unfounded as absolutes like everything else in this hobby they require ‘qualifications’.
daniboun
France (Lyon)
The last 3E audio modules play in the same league and for a modest budget you can do this :
