Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,249
- Likes
- 5,491
I don't see it mentioned here a lot.
How can you tell if a speaker has good transient response?
mm, yes and no. Part of transient response is also how quick the speaker comes to a stop, which we can see in CSD waterfalls.Transient response and frequency response are essentially the same thing. Edit: it's explained a little past half way into the video.
Watch this:
Related yes, the same no....which are also related to frequency response.
In simple terms: the driver is a resonant circuit, driver in a box makes a high pass filter. The Q of the filter defines if the frequency response have a peak at the cut frequency, for fast transient response the Q must be less than one.
More simple: a closed box design with flat response is fast!...more than a vented design
It's valid in the "rigid piston" range up to cone break up (not single piece movement), and very complex at xover points. But any driver at "high frequency" (few octaves over resonance) start to rise impedance and produce little output.Does this apply across the spectrum, or just near Fs?
Psychoacoustically speaking my subjective impression is speakers with more early reflections have worse transient response.
I would have a question though: if I design a closed speaker with a low Q value (to respect the above) what will happen if I use a low shelf filter to "flatten" the frequency response? Will that have a detrimental effect on the transient response?
You need to elaborate a bit more, please....which are also related to frequency response.
The low shelf filter is the boost itself
In the listening room at the listening position
