Transparent DSD DAC/chip
babysnake
Hi
I use HQPlayer to convert all my audio to DSD128 (limited by PC grunt rather than SQ), so no PCM
I'm looking for a DAC or dac chip implementation that will do the absolute electrical minimum required to convert that incoming DSD signal to analogue
Signalyst's own DSC-1/2 does this but I am looking for a more 'mainstream' solution (ie: a box not a board)
Do ESS or AKM chips work like this?
Any suggestions gratefully received
gvl
SoCal
AKM chips have DSD direct mode, some DACs allow to enable it, e.g. the RME ADI-2 DAC (the earlier version that used AKM) at the cost of volume control.
B
babysnake
I have a Topping E30 Mk1 with the AKM chip, but I'm unsure if Direct DSD is enabled by default
Certainly can't find a menu option for it
gvl
SoCal
I don’t think the E30 allows it.
B
babysnake
Ok cheers. Other than the RME is anyone aware of any other dacs where I can use this functionality?
Zek
Maybe old version of Loxjie D30 (with AKM chip)...
gvl
SoCal
Ok, I stand corrected.
Saidera
Adelaide, South Australia, Australia
I've always wanted to use the Direct DSD pathway of chips, including those from Cirrus Logic. But very few implementations allow it.
Snoopy
Smsl D300 has a direct DSD mode and u get to bypass the SDM also.
Saidera
Nutul
U can't adjust volume with DSD at all.
Not to break any belief, but rather than "you can't" I think "you shouldn't", first. Than, the fact that some DAC implementations forbid it, looks more like a proof.
Music1969
Seems that D300 can't be used to adjust volume when playing DSD? D-6 is a better option also with DSD Direct mode explicitly stated on advertising material. I don't see any customer reviews discussing its DSD playback though. https://www.audiosciencereview.com/forum/index.php?threads/smsl-d-6-dac-review.36235/page-12
I have it , very good in DSDD mode
Just make sure you have something after the DAC to control volume
Use Monoprice TRS to XLR balanced cables
So cheap for an excellent balanced out DSDD DAC
b7676
Cs43198/cs43131 has direct DSD mode. It is a little bit better than processing DSD in harmonic distortion but halved in level so worse in SNR and overall THD+N.
Cs43198/cs43131 are multibit delta sigma dacs with very good performance. If there's a way to reduce noise at full level it will be even better.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
My understanding is that is inherent to the DSD format. One of its many limitations is that it has to be converted for there to be any kind of alteration, including volume. Are you saying that's not the case?
Nutul
Absolutely not; on the contrary: since it's transitional (every new bit determines the new level based on the previous) it's almost impossible to modify it on-the-fly, that's why it's sometimes advisable to convert it to Hi-freq PCM if some changes, such as volume adjustment, are to be applied.
