Truthear x Crinacle Zero:RED IEM Review
Rate this IEM:
    Votes: 8 2.1%
    Votes: 13 3.3%
    Votes: 42 10.8%
    Votes: 326 83.8%
GaryH
They come as bundled freebies with several of Sony's cheap Bluetooth receivers which you can still get. The point is the Red has worse treble extension than 10-year-old cheapo earphones, as well as the original Zero.
sharock
So buy a bluetooth device we don't need to get some cheap earphones that look like they isolate so badly you can't hear the extra treble extension?
You just seem to roll out this MH755 dead horse to beat everywhere.:)
That being said, if I could get a pair for £10 I definitely would try them out.
Elitzur–Vaidman
Considering I sometimes find the Red a bit bright/shouty without the impedance adapter, I'm okay with the reduced treble extension.
I should clarify that this is only with some songs at higher volumes. The Reds are unquestionably my the best iems I've owned. Some of that probably has to do with the amazing fit I get with them.
markanini
Scania
Which graphs? As measured on the B&K 5128 with its (purportedly) more accurate upper treble response, the Zero Red has poor treble extension (which contributes to perceived 'detail'), worse than $10 earphones:
As well as worse than the original Zero:
Crinacle says consistent insertion is challenging. BK5128 can't be that reliable for direct treble comparisons.
crinacle
Reviewer
SG
How about a buy and try and then giving an honest assessment? Could add some credibility to the discussion.
As per every single interaction I had with this guy, it's pretty clear that he's only interested in badmouthing and insulting anything that I do. I can predict that if he does buy one, he'll do so for no other reason than to trash it. Guaranteed.
staticV3
I bought like eight pairs of mh755 back when genuine units were still sold on eBay.
With EQ, I think they're fantastic. I still use them on my PC almost every day.
Stock though, they have brain-numbing bass and shouty mids:
Edit: oh whoops I think @GPJ was referring to the Red..
Jimbob54
Edit: oh whoops I think @GPJ was referring to the Red. Haven't bought those yet, probably never will as there's no way my tiny ears can fit that huge shell :(
How do you get a good and secure seal with the 755? Between the janky odd length and twisty Y legs and featherlight shells I cant get them to stay put regardless of tip. Which of course renders them less than useless to me.
staticV3
The included size S tips fit me perfectly and the cable I replaced with MMCX connectors plus an aftermarket cable.
Robbo99999
Those MH755 are insane value when you think about it, plus they've seemingly been around for so long. It's a pity you can't buy them separately anymore.
markanini
Scania
Sony MH755 set the bar for treble, for me. Not too sharp or dull. Not too dry or splashy, just right. The mids are colored, in a reverse-N shape, that makes them rather genre specific. This can be seen in their graph. I've gone through some 10+ sets of genuine MH755. After approximately four months of daily use they develop a channel imbalance.
Robbo99999
Do you reckon that's due to wax blocking up something in the IEM? In my experience headphone drivers are pretty stable and don't degrade, but I have no long term experience of IEM's.
asrUser
This sounds like Sharur. :D
Elitzur–Vaidman
If I had to guess, it's probably poor solder joints.
Robbo99999
Wouldn't that just result in the electronic connections failing, which would either mean total failure (no sound) or cracking sound when moved perhaps.
Elitzur–Vaidman
The wires could be poorly soldered to the iem's drivers which could increase the impedance? If they're single-driver IEMs that would manifest as a sensitivity reduction instead of a FR change.
Baltimore
I was pondering over getting this one or the Moondrop Lan. Then I realized that the Truthear Red are kinda close to the Harman reference from 2016 (that you can find in the autoeq repo). Using my Moondrop Starfield as reference, I would say that while the bass response looks better... the treble extension seems a bit worse. And the treble extension was something I already wished was a better with my Starfields.
The moondrop Lan on the other other hand are cheaper, smaller, studier and prettier. With not so good but still decent bass response and probably better treble. Also better sensitivity and impedance
markanini
Scania
Maybe take it with a grain of salt when comparing measurements between different couplers. But, I'm also curious how these sets compare. I already have the Lan and my Red is in transit.
MacClintock
Mine arrived today. I was quite relieved to see that the rather thick nozzle fitted without problems or causing pain. The sound quality is really very good. They can safely be used without any EQ, without sacrificing sound quality. I perceive no shoutiness, so it is really advantageous not being 100% Harman tuned between 2 and 5 kHz.
If one wants to be very nitpicky, one can show a road of diminishing returns, starting from the KZ D-Fi (got it for $20), the Truthear Zero:Red ($55) and the Moondrop Variations ($520). The D-Fi and the Red have a bit thicker lower mids ("mud") (150-600Hz), the D-Fi the most uneven treble (at 6 and 12 kHz), the Red being in the middle and the Variations being the smoothest. So the Variations does offer the best high fidelity, but for about 20x and 10x the price, respectively. The differences in sound quality are there, but quite minor (especially compared to the Red).
