I'm waiting them to clarify but I am pretty sure they mean they plugged back with 3.5mm into the laptop after the free DSP and didn't have the bass they had with that combo initially.Keep in mind many laptops headphone outputs have out Z of 75 Ohms or higher.
But with higher impedance he should get more bass, if anything...Keep in mind many laptops headphone outputs have out Z of 75 Ohms or higher.
There's no contradiction, he says freedsp has less bass than PC, that follows the output impedance of each device.But with higher impedance he should get more bass, if anything...
my bad, I should learn to read carefully, I understood he switched the Freedsp to the phone and had the problem using the Reds with analog cable on the laptopThere's no contradiction, he says freedsp has less bass than PC, that follows the output impedance of each device.
I had an issue a while back where my left earbud lost most of its output power (particularly bass). I thought it might have been earwax clogging the filter, but even after removing it the volume issue persists. I don't think you blew the drivers without a powerful amp, but there seems to be something that can fail.Is it easy to blow those drivers? I mean i have zero bass right now, after using the FreeDSP cable once without playing any kind stupid levels. My 10y old sony headphone that came for free with an old android phone deliver more bass than those truthears...
@markanini toomy bad, I should learn to read carefully, I understood he switched the Freedsp to the phone and had the problem using the Reds with analog cable on the laptop
do rolled some cable for z1r? or use stock? does worth upgrade to pure 5N silver cable for iem-z1r?I have the crinacle zero which is a fine IEM especially for this price but to manage expectations is nowhere near expensive IEMs like my Sony IER-Z1R
Have to say the stock zero cable is far better than the cables with more expensive iems. It's light, doesn't tangle too easily, totally non microphonic, good construction on the connectors, ear loops are well made and a good shape. Basically perfect.Cables make no difference, change them for better feel, suppleness or because you like the colour or material
The only cable I like more is the one that came with Truthears Hola.Have to say the stock zero cable is far better than the cables with more expensive iems. It's light, doesn't tangle too easily, totally non microphonic, good construction on the connectors, ear loops are well made and a good shape. Basically perfect.
Tye stock cable is great ergonomically with exceptional build quality. I currently use a FiiO cable with detachable connectors. Nothing to mention on sound quality because I didn’t hear any difference. Is just that the FiiO allows greater flexibility between 3.5 and 4.4 connectorsdo rolled some cable for z1r? or use stock? does worth upgrade to pure 5N silver cable for iem-z1r?
because both is copper. need pure silver to get sonically improovement?Tye stock cable is great ergonomically with exceptional build quality. I currently use a FiiO cable with detachable connectors. Nothing to mention on sound quality because I didn’t hear any difference. Is just that the FiiO allows greater flexibility between 3.5 and 4.4 connectors
If you think it's different how would you know silver is better and not worse? Do you think an electron behaves differently moving through silver than copper?because both is copper. need pure silver to get sonically improovement?
They can with poorly designed IEMs which have ridiculous impedance swings.Cables make no difference
