Two speakers, one room.
Vintage57
Ontario, Canada
Here are Dirac Live readings from my listening position of 2 different full range speakers.
When you look at these response curves would you choose one over the other?
Vintage57
Vintage57
Ontario, Canada
The microphone wasn’t moved and the speakers were moved to exactly the same location relative to the front baffle. Tape on hardwood.
DonH56
Monument, CO
First one. Hair smoother, and region from ~55 to 75 Hz not as bad. You are less likely to hear a narrower valley (or peak).
Do be aware frequency response is only part of the story...
